扫一扫,分享给好友
亲爱的,我有关于通过USB端口进行编程控制的问题,当我改变位置USB插件因软件显示错误因为位置USB indirec!请你从软件中获取关于修复端口的建议Best respectbadboy
以上来自于谷歌翻译 以下为原文 Dear all, I have problem about programming control through USB port, When I change position USB for plug in that the software show error because position USB indirec ! Could you please advice about fix port from software Best regard badboy |
据我所知,如果您可以在连接专家中看到该设备,那么它应该是一个简单的修复,只需要给它适当的别名和/或配置来控制VEE。对于没有显示连接的设备
专家,每当您在不同的USB端口插入设备时,它应该安装或要求您安装驱动程序。 我有一个设备识别插入的USB端口,如果我将其插入另一个端口,它停止工作,并要求我安装驱动程序。 我做了之后,它的确有效。 也许这就是你的问题。 以上来自于谷歌翻译 以下为原文 As far as I know, if you can see the device in connection expert, then it should be an easy fix, just need to give it proper alias and/or configuration to control with VEE. For devices that doesn't show up in connection expert, it should install or asks you to install drivers whenever you plug in the device in a different USB port. I had a device that recognize the plugged in USB port, if I plug it in another port, it stopped working and asks me to install driver. After I did, it works. So maybe this is your problem. |
1376 浏览 0 评论
2416 浏览 1 评论
2260 浏览 1 评论
2101 浏览 5 评论
3011 浏览 3 评论
1399浏览 1评论
823浏览 0评论
1170浏览 0评论
1376浏览 0评论
GMT+8, 2025-2-19 09:57 , Processed in 1.315998 second(s), Total 77, Slave 61 queries .
