您好!
使用CY8C27 43-24PXI和C.开发代码 在这一点上,我想从主C代码中调用函数,并希望在汇编中编写函数。 请建议我怎么做。 当做, 以上来自于百度翻译 以下为原文 Hi I am using CY8C27443-24PXI and developing code in C. At this point I want to make function call from main C code and I want to write function in assembly. Please suggest how can I do it. Regards, |
当您在程序集中声明函数时,请确保在函数名前面附加“y”。当你在函数名前面加上“y”时,你可以从C文件中调用函数。下面给出的例子首先导出了其他程序集和C文件的函数。“C MySimultRead”是用于C文件和“MySimultRead”的,用于汇编文件。同样,在定义的时候,我们必须使用两个名称来使这个名称既可用于汇编程序,也可用于C文件。
请注意,从C文件中,也只能调用名为MySimultSead的函数。 导出yMyStudio启动 导出MyStudio启动 StaseStEnSyStRe::StaskSnSeSyStEng:您的函数代码RET一旦完成,就可以在头文件或要调用该函数的C文件中给出函数的原型。最好的问候,Pushek 以上来自于百度翻译 以下为原文 When you are declaring the function in assembly then make sure you have "_" appended in front of the function name. When you are appending "_" in front of the function name then you can call the function from C files. An example given below first of all exports the function for other assembly and C files. "_MyFunc_Start" is for the C files and "MyFunc_Start" is for assembly files. Similarly at the time of definitiion as well, we have to use two names to make this name accessible to both assembly and C files. Please note that from C file as well, you have to call the function with name MyFunc_Start only. export _MyFunc_Start export MyFunc_Start SmartSense_Start: _SmartSense_Start: ; Your function code ret Once done, you can give the prototype of the function in a header file or the c file in which you want to call this function. Best regards, Pushek |
请注意,从C文件中,也只能调用名为MySimultSead的函数。 导出yMyStudio启动 导出MyStudio启动 MySimultStult:YMyMaluxStList:您的函数代码RET一旦完成,就可以在头文件或要调用该函数的C文件中给出函数的原型。最好的问候,Pushek 以上来自于百度翻译 以下为原文 When you are declaring the function in assembly then make sure you have "_" appended in front of the function name. When you are appending "_" in front of the function name then you can call the function from C files. An example given below first of all exports the function for other assembly and C files. "_MyFunc_Start" is for the C files and "MyFunc_Start" is for assembly files. Similarly at the time of definitiion as well, we have to use two names to make this name accessible to both assembly and C files. Please note that from C file as well, you have to call the function with name MyFunc_Start only. export _MyFunc_Start export MyFunc_Start MyFunc_Start: _MyFunc_Start: ; Your function code ret Once done, you can give the prototype of the function in a header file or the c file in which you want to call this function. Best regards, Pushek |
756个成员聚集在这个小组
加入小组2124 浏览 1 评论
1865 浏览 1 评论
3681 浏览 1 评论
1800 浏览 6 评论
1545 浏览 1 评论
605浏览 2评论
450浏览 2评论
448浏览 2评论
400浏览 2评论
1081浏览 2评论
GMT+8, 2025-1-11 11:10 , Processed in 0.780967 second(s), Total 45, Slave 40 queries .
