嗨,
我想知道哪个基于Xilinx FPGA的开发板可以使用单个hdmi或displayport连接器/电缆在25-30Hz或更高频率下输出4k(2160p)? (我可能看起来像oninrevium.com,但基本上没有信息。那里)。 我对develiopmenet环境感兴趣,它允许以这些分辨率执行视频处理并连接到drmi 1.4或DP1.2 谢谢! 然 以上来自于谷歌翻译 以下为原文 Hi, I wonder which Xilinx FPGA-based dev boards can output 4k (2160p) at 25-30Hz or more using a single hdmi or displayport connector/cable is available? (I may have seem something on inrevium.com but there's basically no info. there). I am interested in a develiopmenet environment th that allows to perform video processing at these resolution and connects to hdmi 1.4 or DP1.2 Thank you! Ran |
4个回答
嗨冉,
我建议您完全按照应用笔记的说法开始使用KC705。 如果您花了一些时间进行设计并拥有更多使用经验,那么您可以开始将其迁移到Artix进行最终实施。 迁移到Artix需要一些工作。 www.xilinx.com 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Hi Ran, I'd recommend that you start with the KC705 exactly as the app note is written. When you have spent some time with the design and have more experience with it, then you can start migrating it to Artix for your final implementation. It will take a bit of work to migrate to Artix. www.xilinx.comView solution in original post |
嗨冉,
没有一块电路板本身具有支持4K分辨率的PHY; 你需要一张FMC卡。 Inrevium是赛灵思的合作伙伴,为我们的一些参考设计开发了HDMI 1.4,2.0和DP1.2板。 这里有一些链接可以帮助您入门: http://solutions.inrevium.com/products/fmc/hpc/index.html http://www.xilinx.com/products/intellectual-property/hdmi.html http://www.xilinx.com/products/intellectual-property/ef-di-displayport.html http://www.xilinx.com/support/documentation/application_notes/xapp1178-displayport-transmit.pdf www.xilinx.com 以上来自于谷歌翻译 以下为原文 Hi Ran, None of the boards themselves have PHYs that support 4K resolutions; you need a FMC card. Inrevium is a Xilinx partner who has developed HDMI 1.4, 2.0, and DP1.2 boards for some of our reference designs. Here's some links to get you started: http://solutions.inrevium.com/products/fmc/hpc/index.html http://www.xilinx.com/products/intellectual-property/hdmi.html http://www.xilinx.com/products/intellectual-property/ef-di-displayport.html http://www.xilinx.com/support/documentation/application_notes/xapp1178-displayport-transmit.pdf www.xilinx.com |
好的,确保:
将EnipviumDP1.2 FMC连接到Artix 7套件是否可以解决问题? (即通过单条显示端口电缆显示4k) [我宁愿在应用程序中使用Artix。 请注意你只发送了kintex 7提到] 非常感谢! 然 以上来自于谷歌翻译 以下为原文 OK, to make sure: Will the Inrevium DP1.2 FMC connected to the Artix 7 kit do the trick? (i.e., 4k display though a single displayport cable) [I'd rather go for the Artix yet in the app. note you sent only the kintex 7 is mentioned] Thanks a lot! Ran |
嗨冉,
我建议您完全按照应用笔记的说法开始使用KC705。 如果您花了一些时间进行设计并拥有更多使用经验,那么您可以开始将其迁移到Artix进行最终实施。 迁移到Artix需要一些工作。 www.xilinx.com 以上来自于谷歌翻译 以下为原文 Hi Ran, I'd recommend that you start with the KC705 exactly as the app note is written. When you have spent some time with the design and have more experience with it, then you can start migrating it to Artix for your final implementation. It will take a bit of work to migrate to Artix. www.xilinx.com |
2568 浏览 7 评论
2904 浏览 4 评论
2359 浏览 9 评论
3453 浏览 0 评论
2540 浏览 15 评论
2972浏览 1评论
700浏览 1评论
573浏览 1评论
864浏览 0评论
GMT+8, 2025-4-6 05:32 , Processed in 1.110325 second(s), Total 51, Slave 45 queries .
