Windows 7 64 68013A 128引脚上没有EEPROM CysB.SIS和CysB.INF,INC和LIB文件的自定义板来自CySudio3.4.6
该板使用VID/PID 04B4/8613枚举为“CyPress EZ-USB FX2LP—EEPROM遗失”。 一个使用GPIF示例的OLDBult/FIFO构建并使用KEIL UV2和EZ-USB接口(1.7.0.2)成功下载 一旦下载,它将重新枚举显示“CyPress USB通用驱动程序”在“设备管理器”,但停止了一个代码10错误,使其不可用CySuto等。 它与以前的CysB.SIS驱动程序(04B4/1004)一起工作在XP/32中,这与W-7/64不起作用。 我花了很多时间寻找一个相似的帖子,如果它是一个,就错过了。如有任何建议,将不胜感激。 以下是Keil UV2构建和INF文件的片段: DSC.A51 DeCIEDSCR:DW 0B404H;供应商ID DW01486H;产品ID/DW 01386H;产品ID i包括1004 CysB.Inf;用于X64平台[设备.NTAMD64 ];用于X64平台[设备.NIDAMD64 ] %VIDY04B4&PIDY8613. DeVice DISC%= CYUSB,USB VIDY04B4&PIDY8613%VIDU04B4&PIDY8614 . DeVice DISC%= CYUSB,USB VIDY04B4和PIDY8614 对于X64平台[设备.NTAMD64 ] VIDU04B4&PIDY8613.DEVICESDESC=“CyPress EZ-USB FX2LP -EEPROM遗失”VIDA04B4&PIDY8614.DEVICESDESC =“CyPress USB通用驱动程序(3.4.6000)” 以上来自于百度翻译 以下为原文 Windows 7 64 68013a 128 pin on a custom board with no eeprom CYUSB.sys and CYUSB.inf, INC and LIB files are from CyConsole 3.4.6 The board enumerates using vid/pid 04b4 / 8613 as "Cypress EZ-USB FX2LP - EEPROM missing" A old bulk/fifo with gpif example builds and successfully downloads using Keil UV2 and EZ-USB Interface (1.7.0.2) Once downloaded it will re-enumerate showing "Cypress USB Generic Driver " in the Device Manager" but is stopped with a code10 error making it unavailable to CyConsole etc. It worked with with the previous cyu***.sys driver (04B4 / 1004) in XP/32 which does not work with W-7 / 64 I've spent a lot of time searching for a similar post and missed it if this is one. Any suggestions will be appreciated. Here are snippets from the Keil UV2 build and inf files: dscr.a51 DeviceDscr: dw 0B404H ; Vendor ID dw 01486H ; Product ID // dw 01386H ; Product ID I have tried all 3 including pid 1004 cyu***.inf ;for x64 platforms [Device.NTamd64] ;for x64 platforms [Device.NTamd64] %VID_04B4&PID_8613.DeviceDesc%=CyU***, USBVID_04B4&PID_8613 %VID_04B4&PID_8614.DeviceDesc%=CyU***, USBVID_04B4&PID_8614 [Strings];for x64 platforms [Device.NTamd64] VID_04B4&PID_8613.DeviceDesc="Cypress EZ-USB FX2LP - EEPROM missing" VID_04B4&PID_8614.DeviceDesc="Cypress USB Generic Driver (3.4.6.000)" |
如果您右键单击设备管理器中的设备,那么执行更新驱动程序并指向该INF文件的位置。您得到的错误消息是什么??
当做, 阿南德 以上来自于百度翻译 以下为原文 If you right click the device in device manager then do a update driver and point to the location of this inf file what is the error message you get?? Regards, Anand |
757个成员聚集在这个小组
加入小组2129 浏览 1 评论
1871 浏览 1 评论
3688 浏览 1 评论
1806 浏览 6 评论
1552 浏览 1 评论
622浏览 2评论
461浏览 2评论
457浏览 2评论
412浏览 2评论
1101浏览 2评论
GMT+8, 2025-1-26 09:37 , Processed in 0.666217 second(s), Total 44, Slave 39 queries .
