嗨,
我使用的是SPARTAN 3E XC3500E FPGA,ADC oboard具有3MSPS的差分采样率。 但就我的目的而言,我需要采样速率为80MSPS的ADC。 是否可以通过从外部连接ADC来提高ADC的采样率,还是有其他方法可以满足要求的规格? 谢谢。 以上来自于谷歌翻译 以下为原文 Hi, I am using SPARTAN 3E XC3500E FPGA, The ADC oboard have differential sampling rate of 3MSPS. But for my purpose I require ADC of Sampling Speed 80MSPS. Is it possible to increase the sampling rate of ADC by interfacing ADC from outside or is there any other method to meet the required specification? Thank you. |
如果电路板上ADC的当前时钟速度为3 MHz,那么它的时钟频率极不可能达到80 MHz。
如果你需要这样一个高速ADC,你需要找到另一块板/扩展板上有这样一个ADC。 - 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用且回复的帖子。 以上来自于谷歌翻译 以下为原文 If the current clock speed of the ADC on your board is 3 MHz, it is extremely unlikely that it can be clocked at 80 MHz. If you need such a high speed ADC, you will need to find another board/extension board which such an ADC on it.- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. |
2498 浏览 7 评论
2870 浏览 4 评论
2329 浏览 9 评论
3424 浏览 0 评论
2510 浏览 15 评论
2447浏览 1评论
659浏览 1评论
521浏览 1评论
2075浏览 0评论
801浏览 0评论
GMT+8, 2025-2-24 06:46 , Processed in 1.337112 second(s), Total 77, Slave 61 queries .
