嗨,
我试图在zynq平台上的3.15内核中启用m25p80 spi flash。它在3.12内核中工作正常,但在3.15内核中不会检测到。 我看不到闪存芯片被检测到。 这是输出 zynq-spi e0006000.spi:master已排队,这是deprecatedzynq-spi e0006000.spi:在0xE0006000映射到0xE0818000,irq = 58libphy:XEMACPS mii总线:probedxemacps e000b000.eth:pdev-> id -1,baseaddr 0xe000b000,irq 54ehci_hcd:USB 2.0'增强型'主机控制器(EHCI)驱动程序 任何指针都会有很大的帮助.. 温暖的问候, Ramprasad 以上来自于谷歌翻译 以下为原文 Hi, I am trying to enable m25p80 spi flash in 3.15 kernel on zynq platform.It works fine in 3.12 kernel, but will not detect in 3.15 kernel. I could not see the flash chip getting detected. here is the ouput zynq-spi e0006000.spi: master is unqueued, this is deprecated zynq-spi e0006000.spi: at 0xE0006000 mapped to 0xE0818000, irq=58 libphy: XEMACPS mii bus: probed xemacps e000b000.eth: pdev->id -1, baseaddr 0xe000b000, irq 54 ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver Any pointers will be of great help.. WARM Regards, Ramprasad |
您使用的是哪个版本的Vivado?
您需要使用内核3.15的2014.3或更高版本,如http://www.wiki.xilinx.com/Zynq+2014.3+ReleasePlease,请确保使用兼容的设备树和u-boot。 -------------------------------------------------- ---------------------------------------------请将帖子标记为 如果提供的信息能够回答您的问题/解决您的问题,请“接受为解决方案”。给予您认为有用的帖子。 以上来自于谷歌翻译 以下为原文 Which version of Vivado are you using? You need to use 2014.3 or later versions with Kernel 3.15 as per http://www.wiki.xilinx.com/Zynq+2014.3+Release Please make sure that you use compatible device tree and u-boot.----------------------------------------------------------------------------------------------- Please mark the post as "Accept as solution" if the information provided answers your query/resolves your issue. Give Kudos to a post which you think is helpful. |
2498 浏览 7 评论
2870 浏览 4 评论
2329 浏览 9 评论
3424 浏览 0 评论
2510 浏览 15 评论
2451浏览 1评论
660浏览 1评论
521浏览 1评论
2075浏览 0评论
801浏览 0评论
GMT+8, 2025-2-24 12:22 , Processed in 1.063151 second(s), Total 44, Slave 39 queries .
