您好,我最近有一位客户询问他们如何在HP 8662A上测量60Hz的低频噪声(嗡嗡声),在载波信号下降低-80 dBc。我与几位工程师讨论过,我想也会在这里发布。是的
有一个可靠和可重复的方法来做到这一点? 以上来自于谷歌翻译 以下为原文 Hello, I recently had a customer ask how they might measure low frequency noise (hum) at 60Hz on a HP 8662A, at -80 dBc down from the carrier signal. I discussed with several engineers and thought I would post here as well. Is there a reliable and repeatable way to do this? |
您好 - 您可以使用PXA信号分析仪进行此测量。
PXA在距载波偏移100 Hz时的典型噪声边带性能(相位噪声性能)为-100 dBc / Hz。注意 - 以上来自于谷歌翻译 以下为原文 Hello - You could use a PXA Signal Analyzer to make this measurement. The typical noise side band performance (phase noise performance) for a PXA at a 100 Hz offset from the carrier is -100 dBc/Hz. Regards - |
1383 浏览 0 评论
2419 浏览 1 评论
2266 浏览 1 评论
2105 浏览 5 评论
3019 浏览 3 评论
1418浏览 1评论
827浏览 0评论
1188浏览 0评论
1385浏览 0评论
GMT+8, 2025-2-23 13:13 , Processed in 0.982801 second(s), Total 42, Slave 37 queries .
