嗨,我正在尝试使用Agilent E8257C信号发生器生成FM信号。
你能否告诉我FM_Dev如何被整合到FM信号方程中。 根据我的教科书,如果FM信号的模型是:x(t)= cos(2 pi ft + 2 pi Delta_f y(t))其中y(t)是具有归一化幅度的调制信息音(即最大值) 幅度= 1)。 我将Delta_f定义为频率偏差。 我意识到当我在示波器上设置FM_Dev = 25 KHz(5 KHz增量)时,我得到输出信号(在频谱分析仪上测量),设置中心频率f = 100 MHz和y的FM信号的Delta_f = 0.2 (t)频率为20 KHz。你能告诉我FM_Dev和Delta_f之间的关系是什么?谢谢,Sushil 以上来自于谷歌翻译 以下为原文 Hi, I am trying to generate an FM signal using the Agilent E8257C Signal Generator. Can you please tell me how FM_Dev is incorporated into the FM Signal equation. According to my textbook, if the model for the FM signal is: x(t) = cos (2 pi f t + 2 pi Delta_f y(t)) where y(t) is a modulating information tone which has normalized amplitude (i.e. maximum amplitude = 1). I define Delta_f as the frequency deviation. I realize that when I set FM_Dev = 25 KHz (5 KHz increment) on the scope I get the output signal (measured on Spectrum Analyzer), as setting the Delta_f = 0.2 for an FM signal with the center frequency f = 100 MHz and y(t) is of frequency 20 KHz. Can you please tell me what the relation between FM_Dev and Delta_f is? Thanks, Sushil |
您好 - 当您将FM_Dev设置为25 kHz时,您会得到+/- 25 kHz偏差;
即它将中心频率的每一侧偏离25kHz。 调制频率的大小设定或确定关于中心频率的偏差。 即使E8257C的输入设置为1V进行完全校准,增益也会在源调制电路内变化,以增加或减少偏差。 调制信号(20 kHz)是FM的速率或载波(100 MHz)偏离+/- 25 kHz的速率。注意 - 以上来自于谷歌翻译 以下为原文 Hello - When you set FM_Dev to 25 kHz you get +/-25 kHz deviation; i.e. it deviates each side of center frequency by 25 kHz. The magnitude of the modulating frequency sets or determines the deviation about center frequency. Even though the input to the E8257C is set as 1V for full calibration, the gain is varied inside the source modulation circuits to increase or decrease deviation. The modulation signal (20 kHz) is the rate of FM or the rate at which the carrier (100 MHz) is deviated +/-25 kHz. Regards - |
1353 浏览 0 评论
2408 浏览 1 评论
2236 浏览 1 评论
2092 浏览 5 评论
2983 浏览 3 评论
1321浏览 1评论
800浏览 0评论
1107浏览 0评论
1356浏览 0评论
GMT+8, 2025-2-2 13:18 , Processed in 1.453368 second(s), Total 75, Slave 59 queries .
