嗨,不知道如何将最大输出源9310增加到+30 dbm?从规格显示-127到+13 dBm输出电平范围(最大+20 dBm可设置),我需要+30 dBm。在RF上添加放大器
输出会有帮助吗?请指教。 以上来自于谷歌翻译 以下为原文 Hi, Any idea how i can increase the max output source of 9310 to +30 dbm? From the spec shows -127 to +13 dBm output level range (maximum +20 dBm settable), i need +30 dBm. Adding amplifier at RF output will help? Please advise. |
嗨,感谢您的信息。您可以推荐任何放大器吗?我已经从分布式放大器上的A站点进行了检查。声明所使用的兼容仪器是ESG和PSG,但不适用于N9310A和HMMC-5027 2
-26.5 GHz中等功率放大器对N9310A来说太过分了。你能告诉我N9310A合适放大器的链接吗?非常感谢你。 以上来自于谷歌翻译 以下为原文 Hi, Thanks for the info. Is there any amplifier you can recommend? I have checked from the A-site on Distribution Amplifiers. it is stated the compatible instruments used are ESG and PSG, but not for N9310A. And the HMMC-5027 2-26.5 GHz Medium Power Amplifier are overkill for N9310A. Can you show me the link to the suitable amplifiers for N9310A? Thank you very much. |
Hello Again-与ESG / PSG兼容的放大器也应与N9310A兼容。
有关频率范围,请访问www.agilent.com/find/amplifiers以找到安捷伦的合适解决方案,有来自40 GHz的解决方案.Regards - 以上来自于谷歌翻译 以下为原文 Hello Again - The amplifier which is compatible to ESG/PSG should be also compatible to N9310A. For the frequency range, please go to www.agilent.com/find/amplifiers to find the suitable solution from Agilent, there are solutions from 40 GHz. Regards - |
1342 浏览 0 评论
2401 浏览 1 评论
2232 浏览 1 评论
2088 浏览 5 评论
2980 浏览 3 评论
1294浏览 1评论
792浏览 0评论
1084浏览 0评论
1342浏览 0评论
GMT+8, 2025-1-27 22:11 , Processed in 1.205183 second(s), Total 79, Slave 63 queries .
