HelloIm试图编写代码来计算16位无符号整数乘法的16位的机器周期,IM使用PIC16F87 4 MHz振荡器。我知道在4 MHz时,1个机器周期需要1U。但是我不知道如何用16位无符号整数乘法计算A16位。EG32667 x2= 655 34,这是470个机器周期。谢谢。
以上来自于百度翻译 以下为原文 Hello Im trying to write code for calculating how many machine cycles it takes for a 16-bit by 16-bit unsigned integer multiplication, im using a pic16f877 4 MHz oscillator. i understand that it takes 1us for 1 machine cycle at 4 MHz. but im not sure on how to go about calculating a 16-bit by 16-bit unsigned integer multiplication. eg 32767x2 = 65534 which is 470 machine cycles. Thank you |
4个回答
指令周期为单周期运算码的振荡器/ 4。
以上来自于百度翻译 以下为原文 The instruction time is oscillator /4 for single cycle op-codes. |
这不是太多了,16x16无符号乘法的470条指令吗?
以上来自于百度翻译 以下为原文 Isn't it a bit too much, 470 instructions for a 16x16 unsigned multiplication? |
嗨,XC8通过编译器安装可用的C源函数来完成几乎所有的数学运算。通常可以在MPLAB和计数指令中按语句步进、遵循操作语句或打开反汇编窗口。还存在汇编程序列表报告文件AV。如果有PRO优化的话,可能会有很多源代码的改组。你想预测PIC使用多少条指令吗?对于输入值的所有组合,您可能必须运行时间测量。
以上来自于百度翻译 以下为原文 Hi, XC8 do almost all math like that by c source functions that are available with the compiler installation. It is usually possible to step into, and follow the operations statement by statement, or open disassembly window in MPLAB and count instructions. There is also assembler listing report file available. Then, if there is Pro optimization available, there may be a lot of reshuffling from the source code. Do you want to predict how many instructions PIC is going to use? You may have to run time measurements for all combinations of input values. Regards, Mysil |
你从哪里引用你的470个周期?我会非常失望的例行程序,采取了470个周期乘以32767乘二。
以上来自于百度翻译 以下为原文 Where are you quoting your 470 cycles from? I would be VERY disappointed with a routine which took 470 cycles to multiply 32767 by two. |
5370 浏览 9 评论
2100 浏览 8 评论
2004 浏览 10 评论
3277 浏览 3 评论
2312 浏览 5 评论
880浏览 1评论
769浏览 1评论
706浏览 1评论
764浏览 0评论
653浏览 0评论
GMT+8, 2025-3-7 08:34 , Processed in 1.092328 second(s), Total 48, Slave 43 queries .
