我正在使用Synplify pro进行RTL合成。
我使用2个xilinx coregen PLL,一个产生125MHz,一个产生80MHz。 当我使用125MHz的时钟时,时序报告显示大约105MHz。 然而,当我使用80MHz代替125MHz时,由于某种原因,时序报告显示出最大值。 大约30MHz。 我确实检查了synplify报告,对于125MHz的情况,它显示请求的周期为8ns。 - 这对125MHz是正确的。 但对于80MHz的情况,该报告开始显示1.2ns的请求周期! - 我不确定这是怎么发生的。 我检查了我的PLL,它正在生成正确的频率。 我只限制PLL输入。 可能会出现这样的情况:如果频率低于某个值,那么RTL代码会被合成出来还是什么? 在什么情况下,80MHz的速度可以在最佳情况下提供30MHz的频率,但125MHz的频率为105MHz? 请告诉我...... 感谢致敬, 祖宾库马尔。 以上来自于谷歌翻译 以下为原文 I was using Synplify pro for RTL synthesis. I am using 2 xilinx coregen PLLs, one to generate 125MHz, one to generate 80MHz. When I use a clock of 125MHz, then the timing report comes out showing about 105MHz. However when I use 80MHz in place of the 125MHz, then for some reason the timing report comes out showing a max. of about 30MHz. I did check the synplify reports and for the 125MHz case, it shows requested period as 8ns. – which is correct for 125MHz. But for 80 MHz case, the report starts to show a requested period of 1.2ns! – I am not sure how this can happen. I have checked my PLL and it is generating the proper freq. I am only constraining the PLL input. could there be a situation where if the freq falls below a certain value then the RTL code would get synthesized out or something? In what case would a 80MHz speed give 30MHz in best case freq but 125MHz give 105MHz? Do let me know … Thanks and regards, Zubin Kumar. |
3个回答
忽略Synplify的时间估计。
唯一重要的数字是由布局布线时序分析器生成的数字。 ----------------------------是的,我这样做是为了谋生。 以上来自于谷歌翻译 以下为原文 Ignore Synplify's timing estimates. The only numbers that matter are those generated by the post-place-and-route timing analyzer. ----------------------------Yes, I do this for a living. |
即使我针对特定的xilinx FPGA,我仍然没有回复synplify时序估计吗?
我同意最后的说法是xilinx发布PAR报告,但作为第一次通过,我们可以完全不依赖synplify报告吗? 以上来自于谷歌翻译 以下为原文 even if i target the specific xilinx FPGA, do i still not reply on the synplify timing estimate? i agree that the final say is xilinx post PAR report, but as a first pass, can we not rely on synplify reports at all? |
我很惊讶Synplify弄错了。
我用于Xilinx FPGA的所有工具--Synplify / ISE / Vivado - 都始终通过PLL / MMCM /等正确设置时间。 它始终是有效的,没有我做任何事情。 如果是我,我花了几分钟调查日志文件/等。 试图弄清楚正在发生的事情。 除了限制输入时钟周期之外,你没有做任何“创造性”的事情吗? 但是根据你的描述,它听起来像是一个Synplify问题。 问候, 标记 以上来自于谷歌翻译 以下为原文 I'm surprised Synplify is getting this wrong. All the tools I've used for Xilinx FPGAs - Synplify/ISE/Vivado - all have always managed to time correctly through the PLLs/MMCMs/etc. It's always just worked, without me having do to anything. If it were me, I spend a few minutes investigating the log files/etc. to try and puzzle out what's going on. You're not doing anything "creative" beyond just constraining the input clock period? But from your description it sounds like a Synplify problem. Regards, Mark |
2458 浏览 7 评论
2851 浏览 4 评论
2313 浏览 9 评论
3399 浏览 0 评论
2492 浏览 15 评论
1987浏览 1评论
636浏览 1评论
494浏览 1评论
2041浏览 0评论
768浏览 0评论
GMT+8, 2025-1-25 02:17 , Processed in 1.105037 second(s), Total 46, Slave 41 queries .
