电子发烧友论坛|
为减少数据和时钟偏差,应遵循哪些通用FPGA编码规则?
我学习了FPGA编码和verilog,但我试图找到一些编码规则或约定来提高代码的可靠性。 因为有时模拟的测试结果可能与实现后的测试结果不同并实际上传到FPGA芯片。 我希望通过遵循良好的编码约定来最小化差异。 您能否提供任何建议,指导或链接以便我学习? 谢谢 齐 以上来自于谷歌翻译 以下为原文 What are the general FPGA coding rules that should be followed to reduce the data and clock skew? I learnt FPGA coding and verilog but I am trying to find some coding rules or conventions to increase the reliability of the code. Because sometimes the test outcome of simulation can be different from the test result after implement and actually upload to the FPGA chip. I am hoping to minimize the difference by following a good coding convention. Could you provide with any advice, guidance or links so I can learn? Thanks Qi |
齐,
对于时钟偏差,答案很简单 - 使用Xilinx BUFG。 你完成了。 Xilinx已经在FPGA上创建了一个定制的低偏移时钟网络。 您需要做的就是设置(或推断)BUFG。 至于数据偏差? 为什么? 减少数据偏斜通常不是期望的设计目标。 相反,您只是希望禁止并优化您的设计以满足设置和保持时间目标。 通常,设置时间是重点,只需满足所需的最小数据路径延迟就足够了。 问候, 标记 以上来自于谷歌翻译 以下为原文 Qi, For clock skew, the answer's easy - use a Xilinx BUFG. You're done. Xilinx has created a custom low-skew clock network already on the FPGA. Instatiating (or inferring) a BUFG is all you need to do. As to data skew? Why? Reducing Data skew is generally NOT a desired design goal. Rather, you just wish to contrain and optimize your design to meet setup and hold timing goals. Generally, setup times are the focus, and just meeting the required minimum datapath delay is sufficient. Regards, Mark |
2424 浏览 7 评论
2825 浏览 4 评论
2294 浏览 9 评论
3374 浏览 0 评论
2465 浏览 15 评论
1234浏览 1评论
590浏览 1评论
452浏览 1评论
2006浏览 0评论
731浏览 0评论
GMT+8, 2024-12-25 14:00 , Processed in 1.938500 second(s), Total 77, Slave 61 queries .
