你好,
我已经从xilinx核心生成器生成了三态以太网MAC。 1.具有(MAC速度= 10/100 / 1000Mbps)的三模式以太网MAC,并使用提供的demo_tb运行示例设计。 everithing看起来很棒,它工作得很好。 2.使用MII的三模式以太网MAC(MAC速度= 10 / 100Mbps)并使用提供的demo_tb运行示例设计。 我看到数据从测试平台传输到MII但我没有看到任何来自MAC(local_link)的数据。 看起来它不能正常工作。 你能帮忙吗? 非常感谢 贝纳 everithing看起来很棒,它工作得很好。 以上来自于谷歌翻译 以下为原文 Hello, I've generated the Tri-Mode Ethernet MAC from xilinx core generator. 1. a Tri-Mode Ethernet MAC with (MAC speed = 10/100/1000Mbps) and run the example design with the provided demo_tb. everithing looks great and it s working just fine. 2. a Tri-Mode Ethernet MAC with (MAC speed = 10/100Mbps) working with MII and run the example design with the provided demo_tb. and I see that data is transmited from Test bench to MII BUT I don't see any data coming out from the MAC (local_link) . looks like it doesn't work properly . Can you please assist?? Many thanks Yossi everithing looks great and it s working just fine. |
什么是FPGA器件?
另请参阅http://www.xilinx.com/ipcenter/ipevaluation/temac_evaluation.htm _______________________________________________如果有助于解决您的查询,请将此帖子标记为“接受为解决方案”。 因此,它将有助于其他论坛用户直接参考答案。如果您认为该信息有用且面向答复,请给予此帖子称赞。 以上来自于谷歌翻译 以下为原文 What is the FPGA device? Also refer http://www.xilinx.com/ipcenter/ipevaluation/temac_evaluation.htm ________________________________________________ Please mark this post as an "Accept as solution" in case if it helped to resolve your query. So that it will help to other forum users to directly refer to the answer. Give kudos to this post in case if you think the information is useful and reply oriented. |
该设备是spartan3 dsp。
x3sd3400a-5fg676 以上来自于谷歌翻译 以下为原文 the device is spartan3 dsp. x3sd3400a-5fg676 |
2363 浏览 7 评论
2782 浏览 4 评论
2248 浏览 9 评论
3326 浏览 0 评论
2414 浏览 15 评论
735浏览 1评论
525浏览 1评论
338浏览 1评论
743浏览 0评论
1942浏览 0评论
GMT+8, 2024-11-10 18:34 , Processed in 1.027546 second(s), Total 50, Slave 44 queries .
