你好。
我订购了steval-ihm022v1板。当我熟悉电路板时,我将提供的fw项目(具有较小的适应性)和lcd项目闪存到uC上并且它工作得非常好。但大约一个小时后,显示屏停止显示任何内容。它只是空白。 我试过闪烁lcd和fw项目的各种组合,但显示屏保持空白。 是否可以获取原始闪存映像以验证问题是否与HW无关? 可能是一个lcd测试fw可用于验证显示器? BR, 伯恩哈德 以上来自于谷歌翻译 以下为原文 Hi. I ordered the steval-ihm022v1 board. As I was familiarizing myself with the board I flashed the provided fw project (with small adaptions) and the lcd project onto the uC and it worked quite fine. But after about an hour the display stopped showing anything. It's just blank. I tried flashing various combinations of lcd and fw projects but the display stays blank. Is it possible to get the original flash image to verify that the problem is not HW related? Is maybe a lcd test fw available to verify the display? br, bernhard |
5个回答
你好。
看起来stm3210B-eval板使用与STM32相同连接的相同lcd。因此,我尝试从stm32_gui_lib演示应用程序,效果与显示为空。 我还看了一下连接到LCD的SPI信号,它们看起来很清醒。 因此我得出结论,LCD死在了我身上?有没有人有其他见解? 干杯, 伯恩哈德 以上来自于谷歌翻译 以下为原文 Hi. It looks like the stm3210B-eval board uses the same lcd with identical connection to the STM32. Therefore I tried the demo application from stm32_gui_lib, with the same effect that the display is blank. I also had a look at the SPI signals connected to the LCD, they look sane. Therefore I conclude that the LCD died on me? Does anyone have other insights? cheers, bernhard |
Ciao Bernhard,
在放弃之前,我建议等待新版本的lib。 V3.4。其中一个新功能是: - 增加了对STM3210B-EVAL和STEVAL-IHM022v1标记为MB895 / S C-03的LCD的支持 新的lib将于下周(wk3)或其他(wk4)在st.com上发布,代码为STSW-STM32100 。 再见 梁咏琪 以上来自于谷歌翻译 以下为原文 Ciao Bernhard, before giveup, I suggest to wait the new version of the lib. v3.4. One of the new feature is: - Added the support for the LCD marked MB895/S C-03 of STM3210B-EVAL and STEVAL-IHM022v1 The new lib will be published on st.com next week (wk3) or the other (wk4) with the code STSW-STM32100 . Ciao Gigi |
Ciao Gigi,
听起来不错,所以也许我不必寄回董事会...... 是否可以预先获得测试申请?确保这确实是问题所在。我怀疑二进制LCD项目是否足以进行测试,如果它与v3.3 MC应用程序兼容。 干杯, 伯恩哈德 以上来自于谷歌翻译 以下为原文 Ciao Gigi, sounds great, so maybe I do not have to send back the board... Would it be possible to get a test application beforehand? To ensure this is really the problem. I suspect the binary LCD project would be enough for testing, if it is compatible with the v3.3 MC application. cheers, bernhard |
Ciao Bernhard,
似乎STSW-STM32100已经上网...... 在里面你可以找到STEVAL-IHM022V1_XXX.hex,它是带有更新的LCD FW版本的二进制文件,它也应该与v3.3 MC lib兼容。 再见 梁咏琪 以上来自于谷歌翻译 以下为原文 Ciao Bernhard, it seems that the STSW-STM32100 is already on the web... Inside you can find the STEVAL-IHM022V1_XXX.hex that is the binary with the updated LCD FW version, and it should be compatible also with the v3.3 MC lib. Ciao Gigi |
Ciao Gigi,
谢谢,我将尝试新版本。 IAR没有.out文件,因此我必须使用其他工具编程... BR, 伯恩哈德 以上来自于谷歌翻译 以下为原文 Ciao Gigi, thanks, I'm going to try the new release. There is no .out file for IAR anymore, therefore I have to programm it with another tool... br, bernhard |
2821 浏览 1 评论
3262 浏览 1 评论
1838 浏览 1 评论
3687 浏览 6 评论
6091 浏览 21 评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
391浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
481浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
312浏览 2评论
使用STM32F407VET6的USB2.0功能,发现ctl后芯片无数据返回,是什么原因可能导致的呢?
228浏览 2评论
用STM32G431开发工程,1.50版本的Package包文件无法输出项目工程
333浏览 2评论
GMT+8, 2025-2-1 05:00 , Processed in 0.980698 second(s), Total 52, Slave 47 queries .
