大家好,我的名字是Cosimo,我需要有关步进驱动程序的帮助。
从一台旧打印机我得到了一个双极步进器,现在我正试图用L298和L297配置驱动它。步进输出,L298的输出为:0V 12V 0V 12V。没关系!但是对于电机,L298的输出为:6V 6V 6V 6V。为什么这个? 测试L297输出我没有电机:引脚4 0V,引脚6 4.4V,引脚5 4.4V,引脚7 0V,引脚9 4.4V,引脚8 4.4V。 测试L297输出我用电机:引脚4 0V,引脚6 4.4V,引脚5 2.2V,引脚7 0V,引脚9 4.4V,引脚8 2.2V。 提前致谢。 科西莫 #L298-L297 以上来自于谷歌翻译 以下为原文 Hi to all, my name is Cosimo and I need help about stepper driver. From an old printer I've get a bipolar stepper and now I'm trying to drive it with L298 and L297 configuration. Whitout the stepper the output of L298 are: 0V 12V 0V 12V. It's ok! But with the motor the output of L298 are: 6V 6V 6V 6V. Why this? Testing the L297 output I've without the motor: pin 4 0V, pin 6 4.4V, pin 5 4.4V, pin 7 0V, pin 9 4.4V, pin 8 4.4V. Testing the L297 output I've with the motor: pin 4 0V, pin 6 4.4V, pin 5 2.2V, pin 7 0V, pin 9 4.4V, pin 8 2.2V. Thanks in advance. Cosimo #l298-l297 |
3个回答
解决了!当启动条件为0101且步进电压为12V时,步进电压为6V是正常的..问题是电路板(驱动器L297 + L298和PIC32入门工具包)之间的接地连接和时钟速度为高...感谢所有。
以上来自于谷歌翻译 以下为原文 solved! 6V are normal in stepper when the start condition is 0101 with 12V supply of stepper.. the problem was ground connection between boards (driver L297+L298 and PIC32 starter kit) and clock speed to high.. thanks to all. |
我是一名电气工程专业的学生。我只想问是否需要将光隔离器与L298连接?它没有内置保护吗?
我正在使用带有NXT乐高电机的STM32F303微控制器。电机规格如下: 失速电流:2A 自由运行电流:60mA 以上来自于谷歌翻译 以下为原文 I am an Electrical Engineering student. I just wanna ask whether is there any need to connect optoisolator with L298? Doesn't it has built in protection? I am using STM32F303 microcontroller with NXT lego motors. Specs of motors are: Stall current: 2A Free running current: 60mA |
嗨,
通常在这种应用中不需要光隔离器。 L298集成了热保护功能,您指出的电流额定值均在IC的安全范围内。 恩里科 以上来自于谷歌翻译 以下为原文 Hi, Usually optoisolator are not required in this kind of applications. The L298 integrates thermal protection and the current ratings you indicated are within the safety ranges of the IC. Enrico |
2841 浏览 1 评论
3274 浏览 1 评论
1852 浏览 1 评论
3698 浏览 6 评论
6111 浏览 21 评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
401浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
493浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
322浏览 2评论
使用STM32F407VET6的USB2.0功能,发现ctl后芯片无数据返回,是什么原因可能导致的呢?
240浏览 2评论
用STM32G431开发工程,1.50版本的Package包文件无法输出项目工程
344浏览 2评论
GMT+8, 2025-2-9 06:36 , Processed in 0.954858 second(s), Total 51, Slave 45 queries .
