我正在使用旧的34970A和三个模块: - 旧的34901A - 新的34901A - 新的34903A该软件是Benchlink数据记录器3版本4.2.00问题仅在于第二个34901A模块上的热电偶,更新。
在随机模式下,在扫描期间,热电偶给我一个“OVLD”错误:它完全随机发生! 扫描期间此问题最严重。34970A-34901A / Thremocouples扫描 在第二个模块的扫描中还有其他信号(即电压),它们不会给我这个问题。 还有一个问题可能与第一个问题有关:继电器里程表不适用于第二个34901A模块(那个存在热电偶问题的模块)和34903A模块。 我只能读取数字0,1,-1(?? !!)而不是第一个旧的34901A模块上的关联数字。 这里有关于我的配置:Autozero:启用扫描间隔:30秒TC设置(在两个模块上)NPLC:10通道延迟:自动热电偶:autocheck参考连接温度:内部为了更好地理解,我附上了我的配置文件。 以上来自于谷歌翻译 以下为原文 I'm using an old 34970A with three modules: - an old 34901A - a new 34901A - a new 34903A The software is the Benchlink datalogger 3 ver 4.2.00 The problem is only on the thermocouples on the second 34901A module, the newer. In a random mode, during the scan, the thermocouples give me a "OVLD" error: it happens totally random! This problem get worst during the scan. There are other signals (i.e. voltage) in the scan on the second module and they don't give me this problem. There's one more problem that is probably connected with the first: the relay odometer doesn't works on the second 34901A module (the one on that there's the thermocouples problem) and on the 34903A module. I can only read the number 0, 1, -1 (??!!) instead of the rela number as on the first old 34901A module happens. Here something about my configuration: Autozero: enabled Scan interval: 30 seconds TC settings (on both modules) NPLC: 10 Channel delay: auto Thermocouple: autocheck Reference junction temeperature: internal For better understand I attach my configuration file. 附件
你没有说你把热电偶连接到了什么,但根据我的经验,这有几个原因。
你在某个地方连接不良并且正在打开热电偶读数。 2.您有一个高压电位的热电偶。 3.热电偶安装在高频开关半导体上。 以上来自于谷歌翻译 以下为原文 You did not say what you were attaching your thermocouples to, but in my experience this happens for a couple reasons. 1. You have a bad connection somewhere and are getting an open thermocouple reading. 2. You have a thermocouple on a high voltage potential. 3. You have the thermocouple on a high frequency switching semiconductor. |
1524 浏览 0 评论
2502 浏览 1 评论
2357 浏览 1 评论
2200 浏览 5 评论
3132 浏览 3 评论
1753浏览 1评论
935浏览 0评论
1524浏览 0评论
GMT+8, 2025-5-9 17:31 , Processed in 1.800680 second(s), Total 77, Slave 61 queries .
