你好,
我尝试让I2C接口在没有DMA的情况下工作。 我的初始化看起来如下: Cyu3PrEntStutsUst状态= CyuU3pIn成功;CYU3PI2CCONtiGHT配置;CYU3pDebug打印(4,“CYU3PI2CHIIT…RN”);状态= CYU3PI2CICITE();(状态){Cyu3p3Guin){Cyu3PdClinux(4),“CYU3PI2CHIIT失败,错误代码=%xrn”,状态);返回配置;比特率=100000;配置。ISDMA=CyFalm;CONT.BUTHOUTHOUT 0xFFFFFFFU;COND.MIDATMEOUT=0XFFFF;状态= CYU3PI2CSETCONFIG(ANCOMFIGG,ANS.I2I2CIR);IF(状态)!= Cyu3Upl成功){CyU3pDebug(4),“CYU3PI2CSETCONFIG失败,错误代码= %xrn”,状态);返回状态;} CYU3PI2CSETCONFIG用ErrOr码CyuU3PyErrOrthBADION参数失败。 当设置“组态ISDMA=CyTress”时,CYU3PI2CSETCONFIG返回CYU-U3PY成功。 怎么可能是错的? 最好的问候 G. 以上来自于百度翻译 以下为原文 Hello, I try to get the I2C interface working without DMA. My initialisation looks like following: CyU3PReturnStatus_t status = CY_U3P_SUCCESS; CyU3PI2cConfig_t config; CyU3PDebugPrint (4, "CyU3PI2cInit...rn"); status = CyU3PI2cInit(); if(status != CY_U3P_SUCCESS){ CyU3PDebugPrint (4, "CyU3PI2cInit Failed, Error Code = %xrn",status); return status; } config.bitRate = 100000; config.isDma = CyFalse; config.busTimeout = 0xFFFFFFFFU; config.dmaTimeout = 0xFFFF; status = CyU3PI2cSetConfig(&config, &IS_I2cIR); if(status != CY_U3P_SUCCESS) { CyU3PDebugPrint (4, "CyU3PI2cSetConfig Failed, Error Code = %xrn",status); return status; } CyU3PI2cSetConfig fails with errorcode CY_U3P_ERROR_BAD_ARGUMENT. When setting "config.isDma = CyTrue", CyU3PI2cSetConfig returns with CY_U3P_SUCCESS. What could be wrong? Best regards g. |
你好,
在函数CUU3PI2CSETCONFIG中,第二个参数是回调。只有在使用DMA模式时才使用此回调。因此,如果DMAMODE被设置为CyFalse,那么您不需要传递这个回调参数。这触发了BADI AgulMurnRor。 谢谢, SKSM 以上来自于百度翻译 以下为原文 Hi, In the function CyU3PI2cSetConfig, the second argument is the callback. This callback is used only when the DMA mode is used. So if the DMA mode is set to CyFalse, then you dont need to pass this callback argument. This is triggering the BAD_ARGUMENT error. Thanks, SKSM |
756个成员聚集在这个小组
加入小组2129 浏览 1 评论
1871 浏览 1 评论
3687 浏览 1 评论
1806 浏览 6 评论
1552 浏览 1 评论
622浏览 2评论
460浏览 2评论
455浏览 2评论
408浏览 2评论
1099浏览 2评论
GMT+8, 2025-1-23 10:45 , Processed in 0.692628 second(s), Total 44, Slave 39 queries .
