扫一扫,分享给好友
我的高级工程师负责完成CY7C68013A的C代码,以便在AD ADAU1442 DSP与Windows XP系统之间的接口,然后是Android。所以,我必须接管并重新开始。这个CyPress控制器有C代码,我可以下载吗?有没有使用CyPRS USB外设控制器来与模拟设备的音频DSP Sigma Studio开发软件交谈的应用笔记/示例?有人想签合同吗?在DSP板上附上CY7C68013A示意图。
原理图1页6 PDF 24.1 K 以上来自于百度翻译 以下为原文 My senior engineer who was responsible for completing the C code for the CY7C68013A to interface between an AD ADAU1442 DSP to a Windows XP system and then to Android has fallen ill (long term). So, I have to take over and start again. Is there C code for this Cypress controller that I can download? Are there any application notes/examples for using the Cypres USB peripheral controller to talk to an Analog Devices' audio DSP Sigma Studio development software? Anyone want a contract to get this done? Schematic of CY7C68013A on the DSP board is attached.
你好,
FX2LP系列的所有资源都可以在这里找到: HTTP://www. CyPress?COM/?ID=193 在这个页面的右边是一个叫做“相关文档”的部分。这包含了所有的应用笔记、数据表、模型等。 对于在设计过程中可能出现的特定问题,请点击顶部“菜单栏”中的“我的帐户”-gt;“MyBox”创建一个威廉希尔官方网站 支持案例。 谢谢, 阿努普 以上来自于百度翻译 以下为原文 Hello, All the resources for the FX2LP series can be found here: http://www.cypress.com/?id=193 On the right side of this page is a section called "Related Documentation". This contains all the application notes, datasheets, models etc. For specific issues that may arise during your design, please create a tech-support case by clicking on "My Account" -> "MyCases" in the menu bar on top. Thanks, Anup |
760个成员聚集在这个小组
加入小组2151 浏览 1 评论
1897 浏览 1 评论
3718 浏览 1 评论
1829 浏览 6 评论
1574 浏览 1 评论
778浏览 2评论
536浏览 2评论
482浏览 2评论
443浏览 2评论
1138浏览 2评论
GMT+8, 2025-2-24 06:02 , Processed in 0.930164 second(s), Total 77, Slave 61 queries .
