我们最近遇到了Xilinx许可证的问题。
从Linux与Windows检查时,我看到了不同的许可证状态。 我不知道它是怎么发生的,但我想知道许可证服务器是否有不同的视图或许可证状态缓存,具体取决于它检查的机器类型或检查的机器类型。 此时,Linux上的lmstat表明Vivado_System_Edition和SDK的所有许可证都在使用中,但是从WinPC中它表示没有签出许可证。 现在,我无法使用Linux中的工具,因为它报告“找不到有效的功能许可”综合“......” 有没有其他人经历过这个? 谢谢 以上来自于谷歌翻译 以下为原文 We have been having trouble with the Xilinx licenses lately. I see different license status when checking from Linux vs. Windows. I don’t know how it can happen, but I wonder if somehow the license server has a different view or cache of license status depending on what type of machine it is checking from or what type of machine it was check out from. At this moment, lmstat on Linux is indicating that all licenses of Vivado_System_Edition and SDK are in use, but from WinPC it says no license are checked out. Right now, I can not use the tools from Linux since it is reporting “A valid license was not found for feature “Synthesis”…" Anybody else experiencing this? Thanks |
嗨,你能在两台机器上分享lmutil lmstat的输出吗?谢谢,Vinay
-------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hi, Can you share the output of lmutil lmstat on both machines? Thanks, Vinay-------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
2496 浏览 7 评论
2870 浏览 4 评论
2328 浏览 9 评论
3424 浏览 0 评论
2510 浏览 15 评论
2436浏览 1评论
658浏览 1评论
519浏览 1评论
2073浏览 0评论
800浏览 0评论
GMT+8, 2025-2-23 12:49 , Processed in 1.204367 second(s), Total 75, Slave 59 queries .
