嗨,
我正在为无线OFDM收发器实现信道均衡器,现在的问题是我无法找到OFDM 在系统生成器中实现的收发器模型。 所以,如果有人帮我找到在sys gen中实现的无线OFDM(802.11a)收发器模型。 谢谢 以上来自于谷歌翻译 以下为原文 Hi, I am implementing the channel equalizer for wireless OFDM transceiver, Now problem is that I am unable to find the OFDM transceiver model implemented in the system generator. So, if somebody help me find wireless OFDM (802.11a) transceiver model implemented in sys gen. thanks |
嗨,
sysgen中没有OFDM模块,请查看以下链接并按照建议操作 http://forums.xilinx.com/t5/General-Technical-Discussion/ofdm-using-system-generator/td-p/163008 http://forums.xilinx.com/t5/Digital-Signal-Processing-IP-and/OFDM-modulator/td-p/28224 -------------------------------------------------- -------------------------------------------请在发布前进行谷歌搜索, 您可能会找到相关信息。请留下帖子 - “接受为解决方案”,如果提供的信息有用且回复,请给予赞誉 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Hi, There is no OFDM block in sysgen, please check below links and follow the suggestions http://forums.xilinx.com/t5/General-Technical-Discussion/ofdm-using-system-generator/td-p/163008 http://forums.xilinx.com/t5/Digital-Signal-Processing-IP-and/OFDM-modulator/td-p/28224 --------------------------------------------------------------------------------------------- Please do google search before posting, you may find relavant information. Mark the post - "Accept as solution" and give kudos if information provided is helpful and reply oriented View solution in original post |
嗨,
sysgen中没有OFDM模块,请查看以下链接并按照建议操作 http://forums.xilinx.com/t5/General-Technical-Discussion/ofdm-using-system-generator/td-p/163008 http://forums.xilinx.com/t5/Digital-Signal-Processing-IP-and/OFDM-modulator/td-p/28224 -------------------------------------------------- -------------------------------------------请在发布前进行谷歌搜索, 您可能会找到相关信息。请留下帖子 - “接受为解决方案”,如果提供的信息有用且回复,请给予赞誉 以上来自于谷歌翻译 以下为原文 Hi, There is no OFDM block in sysgen, please check below links and follow the suggestions http://forums.xilinx.com/t5/General-Technical-Discussion/ofdm-using-system-generator/td-p/163008 http://forums.xilinx.com/t5/Digital-Signal-Processing-IP-and/OFDM-modulator/td-p/28224 --------------------------------------------------------------------------------------------- Please do google search before posting, you may find relavant information. Mark the post - "Accept as solution" and give kudos if information provided is helpful and reply oriented |
2436 浏览 7 评论
2833 浏览 4 评论
2303 浏览 9 评论
3383 浏览 0 评论
2475 浏览 15 评论
1480浏览 1评论
601浏览 1评论
467浏览 1评论
2019浏览 0评论
741浏览 0评论
GMT+8, 2025-1-2 04:24 , Processed in 1.220990 second(s), Total 48, Slave 42 queries .
