达到目的:9999---9998---9997---0
目前状态:9999---9998---9999---9998...只减一次又恢复 int timeCheck; int main(void) { int a=9999; int aj; GPIO_Num_Init(); delay_ms(200); GPIO_SetBits(GPIOA,GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7);//???λ? while(1) { for( TImeCheck = 0; TImeCheck<60; TImeCheck++ ) { aj=a; delay_ms(50); DisPlayNum(aj); } TImeCheck=0; delay_ms(5000); a--; GPIO_SetBits(GPIOA,GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7); } } void DisPlayNum(int n) { if (n < 10000) { int i; int s; s=n; i=0; for (i=0;i<5;i++) { GPIO_SetBits(GPIOB,GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_10|GPIO_Pin_11); switch (i) { case 0: GPIO_ResetBits(GPIOB,GPIO_Pin_11); //GPIO_Write(GPIOE,table[n % 10]); n=n/10; break; case 1: GPIO_ResetBits(GPIOB,GPIO_Pin_10); //GPIO_Write(GPIOE,table[n % 10]); n=n/10; break; case 2: GPIO_ResetBits(GPIOB,GPIO_Pin_1); break; case 3: GPIO_ResetBits(GPIOB,GPIO_Pin_0); //GPIO_Write(GPIOE,table[n % 10]); n=n/10; break; } switch (s%10) { case 0: GPIO_Write(GPIOA,table[0]); break; case 1: GPIO_Write(GPIOA,table[1]); break; case 2: GPIO_Write(GPIOA,table[2]); break; case 3: GPIO_Write(GPIOA,table[3]); break; case 4: GPIO_Write(GPIOA,table[4]); break; case 5: GPIO_Write(GPIOA,table[5]); break; case 6: GPIO_Write(GPIOA,table[6]); break; case 7: GPIO_Write(GPIOA,table[7]); break; case 8: GPIO_Write(GPIOA,table[8]); break; case 9: GPIO_Write(GPIOA,table[9]); break; //default: //???????IO????? //break; } delay_ms(2000); s=s/10; if(s==0) break; } } } |
3个回答
4位数码管静态显示没问题,动态也能切换。但是我要实现从9999递减到0,可程序仿真时能递减,但烧录到板子上只9999--9998---9999-9998.。。。。。这样循环?哪位帮忙分析一下,谢谢!
2272 浏览 1 评论
AD7686芯片不传输数据给STM32,但是手按住就会有数据。
2083 浏览 3 评论
4708 浏览 0 评论
如何解决MPU-9250与STM32通讯时,出现HAL_ERROR = 0x01U
2229 浏览 1 评论
hal库中i2c卡死在HAL_I2C_Master_Transmit
2773 浏览 1 评论
GMT+8, 2024-12-27 18:43 , Processed in 0.495860 second(s), Total 49, Slave 42 queries .
