扫一扫,分享给好友
嗨,大家好,
我们已经使用EZ-USB多年来为我们的产品构建应用程序没有任何问题。最近,我们已经切换到Windows 7(32位),甚至在安装CyUSB到RePaseZZ USB之后,在Windows 7下运行的HOX2BIX有间歇性的问题。 当来自命令提示符的Irun Hx2BIX失败时(如Windows所报告的)大约25%的时间(五次或六次尝试中的一次或两次)。还有其他人看到这种行为吗?我试着改变程序的兼容性模式,但是这会导致Windows询问是否允许程序每次运行时对系统进行更改(典型的编译编译有十几个模块,所以是PIA)。 谢谢, 斯科特 以上来自于百度翻译 以下为原文 Hi all, We've been using EZ-USB for many years to build applications for our products without any problem. Recently we've switched to Windows 7 (32-bit), and even after installing CYUSB to replace EZ-USB, are having intermittent problems running hex2bix under windows 7. When I run HEX2BIX from a command prompt it fails (as reported by windows) about 25% of the time (once or twice out of five or six tries). Has anyone else seen this behavior? I've tried changing the program's compatibility mode, but this causes Windows to ask if it's OK to let the program make changes to the system every time it runs (a typical build compiles a dozen modules, so that's a PIA). Thanks, Scott |
斯科特,
您可以在C:CyPress USB UTILHOX2BIX中找到HOX2BIX的来源。试着用VisualStudio的后期版本编译它,比如说VS2008。我会检查我是否能抓住Win 7的机器并找出这个问题是什么。 当做, 阿南德 以上来自于百度翻译 以下为原文 Scott, You can find the source of Hex2bix in C:CypressUSBUtilHex2Bix. Try compiling it with the later versions of visual studio, say VS2008. I'll check if i'm able to catch hold of a Win7 machine and figure out what this issue is all about. Regards, Anand |
754个成员聚集在这个小组
加入小组2106 浏览 1 评论
1853 浏览 1 评论
3671 浏览 1 评论
1786 浏览 6 评论
1536 浏览 1 评论
572浏览 2评论
424浏览 2评论
438浏览 2评论
386浏览 2评论
916浏览 2评论
GMT+8, 2024-12-25 01:57 , Processed in 0.748757 second(s), Total 44, Slave 38 queries .
