我怎么知道CY7C68013是枚举的?我需要发送通知的硬件(通过固件),USB电缆已被拔出。
以上来自于百度翻译 以下为原文 How can I tell that the CY7C68013 is enumerated? I need to send notification to the hardware (via firmware) that the USB cable has been unplugged. |
在自供电设计中,您必须监视VBUS以获得正确的USBbehavior:请查看CyPress AN15813的详细信息。这样做,你有一个关于电缆插头的信息。您还可以查看“StTeS配置”命令,但这只在TEH主机的插件和成功枚举调用。除此之外,在移除USB电缆后没有软件命令。
以上来自于百度翻译 以下为原文 In a self powered design you have to monitor the VBus for correct USB behavior: Take a look into the Cypress AN15813 for details. Doing this, you have an information about the cable plugged or not. You can also watch the "SetConfiguration" Command, but this is only called at Plug-In and successfull enumeration by teh host. AFAIK there is no software command after removing the USB cable. |
754个成员聚集在这个小组
加入小组2106 浏览 1 评论
1853 浏览 1 评论
3671 浏览 1 评论
1788 浏览 6 评论
1536 浏览 1 评论
572浏览 2评论
424浏览 2评论
438浏览 2评论
386浏览 2评论
916浏览 2评论
GMT+8, 2024-12-25 09:07 , Processed in 0.930125 second(s), Total 45, Slave 40 queries .
