HPYMABX X与PIC18F45 K40不使用PICkiti,使用MPLAB IDV 3.30,当我选择PIC18F24J11时,在MPLAB X中出现PICTIT3,但是当我选择PIC18F45 K40时,在MPLAB X中看不到PICTIT3,你知道我做错了什么吗?我该怎么修理呢?感谢帮助
以上来自于百度翻译 以下为原文 Hi MPLAB X only with PIC18F45K40 don't cooparete with PICkit I use MPLAB IDE v 3.30 When I choose for example PIC18F24J11 then in MPLAB X appear PICkit3 But when I choose PIC18F45K40 then in MPLAB X don't see PICkit3 Do You know what I doing wrong? How I can fix it? Thank for help |
3个回答
K40可能是你能得到的最新PIC18之一,你的IDE版本不是!你可能需要安装一个较新的;
以上来自于百度翻译 以下为原文 The K40 is probably one of the newest PIC18 you can get. Your version of the IDE is not! You probably have to install a more recent one ;-) |
嗨,正如VLOKI所提到的,对于最近的PIC18FXXK40家族,你需要安装最新的MPLAB X(V3.61)以及最新的XC8编译器(V1.42)。NB:你不需要卸载当前的MPLAB X版本来安装新的MyAB版本,以防万一你想保留它。
以上来自于百度翻译 以下为原文 Hi, As mentioned by VLOKI, for the very recent PIC18FxxK40 family, you need to install the latest MPLAB X (v3.61) as well as the latest XC8 compiler (v1.42). NB : you do not need to uninstall your current MPLAB X version to install the new one just in case you want to keep it ;=) Regards |
5341 浏览 9 评论
2084 浏览 8 评论
1988 浏览 10 评论
3265 浏览 3 评论
2301 浏览 5 评论
846浏览 1评论
741浏览 1评论
683浏览 1评论
739浏览 0评论
630浏览 0评论
GMT+8, 2025-2-12 09:25 , Processed in 0.478656 second(s), Total 47, Slave 42 queries .
