扫一扫,分享给好友
你好
我在PSoC Creator身上发现了一个错误。对不起,如果这是一个副本,但我不知道我应该在哪里寻找目前的错误报告(我应该把我的报告,以及在哪里)。 当我打开TopDebug .CysCH文件并尝试在任何组件上使用“打开数据表”命令时,我会得到以下错误: GDE.M025:不能启动PDF阅读器无法启动PDF阅读器。安装PDF阅读器并确保它与PDF文件相关。在完成此操作之前,此应用程序将无法显示组件数据表。但是,当使用组件目录工具窗口打开数据表时,所有的工作都很好。 在此之后,尝试在TopDead窗口中打开任何组件的数据表将打开数据表,但不打开所选组件。它将是当前在组件目录窗口中选择的组件的数据表。 我很抱歉我的英语,但我希望你明白我的意思。 我的软件: PSoC Creator 1 PRD(7727) PDF阅读器:FXIT阅读器4.3.1.0218 操作系统:WindowsXP SP3 最好的问候 托马斯 UpopReVIEW弹出式UpPopReVIEW弹出式UpReopVIEW弹出窗口 以上来自于百度翻译 以下为原文 Hello I have found a bug in PSoC Creator. I'm sorry if this is a duplicate, but I don't know where should I look for current bug reports (and where should I put my report as well). When I open a TopDesign.cysch file and try to use the "Open Data Sheet" command on any component I get the following error: gde.M0025: Cannot launch PDF reader Unable to launch a PDF reader. Install a PDF reader and make sure that it is associated with PDF files. Until this is done, this application will not be able to display component data sheets. However, when I use the Component Catalog tool window to open datasheets everything works fine. After this, trying to open a datasheet for any component in the TopDesign window will open a datasheet, but not for the selected component. It will be datasheet for the component that is currently selected in the Component Catalog window instead. I am sorry for my English, but I hope you understand what I mean . My software: PSoC Creator 1.0 Prod (7727) PDF Reader: Foxit Reader 4.3.1.0218 OS: Windows XP SP3 Best regards Thomas usoPreviewPopup usoPreviewPopup usoPreviewPopup
5个回答
托马斯
你的英语很好。谢谢你报告这个问题。我们将打开BAHVIVE,打开PDF文件。 如果你发现更多的问题与Creator,这是一个很好的地方张贴,我们正在检查论坛非常定期。 罗伯特 以上来自于百度翻译 以下为原文 Thomas, your English is just fine. Thank you for reporting this issue. We will look into the bahaviour with opening PDF files. If you find more problems with Creator, this is actually a good place to post, we are checking the forum very regularly. Robert |
我和PSoC Creator 1也有同样的行为。
“获取数据表”结果 “GDE.M025:不能启动PDF阅读器。无法启动PDF阅读器。安装PDF阅读器并确保它与PDF文件相关。在完成此操作之前,此应用程序将无法显示组件数据表。 我使用FXIT阅读器4.3.1.0323,它作为默认PDF处理程序注册在WindowsXP SP3上。 试图避免使用AcROBLUAT,所以我可能只会制作一个HTML页面,链接到所有的PDF文件。 以上来自于百度翻译 以下为原文 I have the same behavior happening with PSoC Creator 1.0. "Get Data Sheet" results in "gde.M0025: Cannot launch PDF reader. Unable to launch a PDF reader. Install a PDF reader and make sure that it is associated with PDF files. Until this is done, this application will not be able to display component data sheets." I use Foxit Reader 4.3.1.0323, which is registered as the default pdf handler, on Windows XP SP3. Trying to avoid using Acrobloat, so I will probably just make an HTML page with links to all the pdfs. |
@ Idonthaveanickname:
如果您不想制作HTML文件,请记住您可以通过右键单击组件目录窗口中的组件来打开数据表。这对FoxitReader来说很好。 问候汤姆 以上来自于百度翻译 以下为原文 @Idonthaveanickname: If you don't want to make a HTML file, remember that you can open datasheets by right clicking components in the Component Catalog window. It works fine with FoxitReader. Regards Tom |
我使用PDF Xchange Pro(FER 2.0.54)和PSoCuC求V1.0.0.77 27遇到同样的问题。
我可以确认,从目录的上下文菜单访问数据表也很好。 到目前为止,这只是一个非常糟糕的IDE中唯一的故障。我希望这样的小问题能尽快解决。 PCPETE 以上来自于百度翻译 以下为原文 I'm experiencing the same problem using PDF X-Change Pro (ver 2.0.54) and PSoC Creator ver 1.0.0.7727. I can confirm that accessing the datasheet from the catalogue's context menu also works fine. So far, this is the only glitch in what is otherwise a pretty damn nice IDE. I hope such a minor issue can be fixed soon. -PCPete |
嗯,有趣。
第三次启动PSoC Creator时,我意外地点击了我已经在PDF查看器应用程序中打开的组件的数据表按钮,通过组件目录,应用程序焦点切换到查看器。 现在我不能复制原来的问题,所以我不能告诉它是否是 A)事实上,这不是我第一次运行应用程序(可能是在应用程序关闭时更新了注册表值),或者 b)如果它与文档在外部应用程序中已经打开有关。 不管怎样,值得一试。 祝你好运! 以上来自于百度翻译 以下为原文 Hmm. Interesting. The 3rd time I started PSoC Creator, I "accidentally" clicked on the Data Sheet button for a component that I already had open in my PDF Viewer app via the Component Catalog, and the application focus switched to the viewer. Now I can't duplicate the original problem, so I can't tell if it was a) the fact that this wasn't the first time I'd run the app (indicating maybe a registry value updated on app closure), or b) if it had something to do with having the document already open in the external app. Either way, it's worth a try. Good luck! |
751个成员聚集在这个小组
加入小组2062 浏览 1 评论
1818 浏览 1 评论
3629 浏览 1 评论
1757 浏览 6 评论
1504 浏览 1 评论
491浏览 2评论
347浏览 2评论
407浏览 2评论
352浏览 2评论
844浏览 2评论
GMT+8, 2024-11-15 06:41 , Processed in 0.677601 second(s), Total 53, Slave 48 queries .
