你好
我尝试命令行编译。把一切都变成文章。我写BAT文件 设置pSOCooToCs=“C:SoPress PSoC设计器 5.1 CyPaseBuyBudidMrgToots”SET设备= Cy7C638 13-SXC设置BaseDeigner=Cy7C638 00设置LaSTROM=0x1FFF设置路径= %PSoCooSoCs%make -F%PSoCooCals%%MaFraseCurror make PrimeNe= Test1-F%PSoCootos%MaFrimeMakMeMeK-make -F%PSoCootos%MaxFiFILe取决于使项目名称= Test1-F%PSoCootos%MaFag文件暂停 出现下一个错误。 U:CysPosiesTest1Test1- f;“C:\程序文件 CyPress PSoC设计器 5.1 CyPlasBuyBudidGrToo\MaMekMakimk PoSoMaKeMaKe.EXE TEST1 OOPROCTOR.MK作出:**[MAKEMACK]错误- 1073741819 我怎样才能解决这个错误呢? 有人有命令行编译的其他示例吗? 提前感谢。 以上来自于百度翻译 以下为原文 Hello I try command line compilation. Make all like in article . I write bat file set PSOCTOOLS="C:Program FilesCypressPSoC Designer5.1CommonCypressSemiBuildMgrtools" set DEVICE=CY7C63813-SXC set BASEDEVICE=CY7C63800 set LASTROM=0x1fff set path = %PSOCTOOLS% make -f %PSOCTOOLS%Makefile clean make PROJNAME=test1 -f %PSOCTOOLS%Makefile makemake make -f %PSOCTOOLS%Makefile depend make PROJNAME=test1 -f %PSOCTOOLS%Makefile PAUSE The next error appear. U:cyprojectstest1test1>make PROJNAME=test1 -f "C:Program FilesCypressPSoC Designer5.1CommonCypressSemiBuildMgrtools"Makefile makemake psocmakemake.exe test1 -oproject.mk make: *** [makemake] Error -1073741819 How can I resolve this error. Do somebody have other sample of command line compilation? Thanks in advance. |
7个回答
你好,
我们高度鼓励我们的社区参与进来并回答问题。有其他人遇到这个问题。在我们的测试环境中,知识库文章“PoSOC1项目的命令行编译”中所描述的方法是有效的。 是否有人使用这个特性,它不起作用。 论坛的目标是成为用户社区和对等网络的共享和帮助网络。 我们将继续研究这个问题,并欣赏来自其他PSoC用户的任何额外输入。 谢谢你的帮助,罗伯特 以上来自于百度翻译 以下为原文 Hi, we highly encourage our community here to jump in and answer questions as well. Has somebody else encountered this issue. In our test environment the approach as described in the knowledge base article "Command Line Compilation of PSoC1 Project" does work. Is somebody else using this feature and it does / does not work. The forum is targeted to be a user community and a peer to peer sharing and help network. We will continue to look into this issue and appreciate any additional input from other PSoC users. Thank you for your help, Robert |
根据《IDE用户指南》附录B.4“通过命令行建设项目”。
下面的命令应该用于清理、生成和生成由IDECIFRAP编译器生成的“演示”项目,该项目位于“D:MyDealDead”文件夹中: “C:程序文件 CyPress PSoC设计器 5.1 PSoC设计器5 PDCL.exe”“cgbp”“d:MyDesigndemo demo .CMX”“IcCeCfRAPP” 此命令只能用于PD 5.1设计器。 请参阅P134附带的“IDE用户指南.pdf”文件 IDE用户指南1.PDF 6.5兆字节 以上来自于百度翻译 以下为原文 According to the “IDE User Guide” Appendix B.4 “Building Project Through Command Line”. The following command should be used to Clean, Generate and Build by the IMAGECRAFT compiler the “Demo” project, located in the “D:MyDesigner” folder: "C:Program FilesCypressPSoC Designer5.1PSoC Designer 5PDCLI.exe" "CGBP" "D:MyDesignerDemoDemo.cmx" "IMAGECRAFT" This command can be used only for the PD 5.1 designer Please see attached “IDE User Guide.pdf” file on p134
我也不能用这样的方式来构建我的项目。
C:文档和设置admin & gt;“C:程序文件 CyPress PSoC设计器 5.1 PSoC设计器5 PDLI.exe”“CGBP”“C:PSoC项目Test1Test1.CCMX”“IcCeFrPad”过程……错误:无法建立建设项目的输出如下所示:做 你能给我你的电子邮件或Skype吗? 我给你我的计算机远程控制的登录名和密码。 我的联系人是 电子邮件:RuSLAN-Dely.信息 Skype:Rasal.DelyIn信息 以上来自于百度翻译 以下为原文 I can't build my project this way too. C:Documents and Settingsadmin>"C:Program FilesCypressPSoC Designer5.1PSoC Designer 5PDCLI.exe" "CGBP" "C:PSoC projectstest1test1.cmx" "IMAGECRAFT" Process ................ ERROR: The project failed to build The build output is shown below: done Can you give me your email or skype? I send you login and password for remote control of of my computer. My contacts are email: ruslan@delly.info skype: ruslan.delly.info |
您使用的是PSoC设计器的哪个版本?(关于PSoC设计器的帮助& GT)
我可以用PSoC设计器5.1服务包1成功地构建,它可以从 HTTP://www. CyPress?COM/?RID=41083 你可以附上你的项目吗? 以上来自于百度翻译 以下为原文 Which version of the PSoC Designer are you using? (Help -> About PSoC Designer) I can successfully build with PSoC Designer 5.1 Service Pack 1, which can be downloaded from the http://www.cypress.com/?rID=41083 Could you attach your project? |
我用
PSoC设计器内容5.1(SP1)-构建2101 - 27 -DECEMBO-2010.15:17:09 PSoC设计器核心5.1(SP1)-构建2101 -27至DeMeBe-2010.15:17:09 PSoC设计器文档5.1(SP1)-构建2101 -27至DeMeBe-2010.15:17:09 我也可以用www. TeaVIEWRel.com共享我的电脑。 密码和登录可以发送到您的电子邮件。 以上来自于百度翻译 以下为原文 I use PSoC Designer Content 5.1 (SP1)- Build 2101 - 27-December-2010.15:17:09 PSoC Designer Core 5.1 (SP1)- Build 2101 - 27-December-2010.15:17:09 PSoC Designer Documentation 5.1 (SP1)- Build 2101 - 27-December-2010.15:17:09 I also can share my computer using www.teamviewer.com Password and login can send to your email. |
我的项目链接是
Test.DelyIf/Test1.Zip 以上来自于百度翻译 以下为原文 My project link is test.delly.info/test1.zip |
鲁斯兰
请使用下面的BAT来构建你的项目(感谢克里斯的帮助): 设置设备= CY7C638 13-SXC 设置基本设备= CY7C638 设置拉斯特罗姆=0x7FFF 设置项目名称= Test1 设置PSoCoDiR= C:Prima~(1) CyPress pSoDe~(1)5.1 CyPrs~3工具 设置路径=%PSoDoC% 回声清洁 使-f%pSOCIDR%%MaCH文件干净 回声马克斯马克 使-f%pSOCDIr%%MaMekMakimk 回波依赖 使-f%pSOCIDR%%MaFigFrm依赖 回音生成文件 使-f%pSOCIDR%%Mag文件 它应该解决你的问题。KB和IDE用户指南将被更新。 以上来自于百度翻译 以下为原文 Ruslan, please use following bat to build your project (thanks Chris for help): set DEVICE=CY7C63813-SXC set BASEDEVICE=CY7C63800 set LASTROM=0x7fff set PROJNAME=test1 set PSOCDIR=C:PROGRA~1CypressPSOCDE~15.1CommonCYPRES~3tools set PATH=%PSOCDIR% echo clean make -f %PSOCDIR%Makefile clean echo makemake make -f %PSOCDIR%Makefile makemake echo depend make -f %PSOCDIR%Makefile depend echo MakeFile make -f %PSOCDIR%Makefile It should solve your issue. KB and IDE user guide will be updated. |
741个成员聚集在这个小组
加入小组2002 浏览 1 评论
1761 浏览 1 评论
3545 浏览 1 评论
1696 浏览 6 评论
1466 浏览 1 评论
273浏览 2评论
170浏览 2评论
355浏览 2评论
299浏览 2评论
487浏览 2评论
GMT+8, 2024-9-20 15:30 , Processed in 1.033339 second(s), Total 57, Slave 52 queries .
