扫一扫,分享给好友
大家好,
我一直试图编写一个CY8C3666 AXI-040 ES1,它提供了一个初步的CY8CITK-1001 ReV5 PSoC开发工具包,并且似乎已经走到了死胡同。 ES1设备修订在PSoC创建者1中是不可选择的,并且当试图编程时报告以下错误: “选定的调试目标”CY8C3666 AXA040 ES1’与项目选定的设备“CY8C3666 AXI-040 ES2”不兼容。 我知道芯片被检测为“AXA”,而不是“AXI”,但选择一个“AXA”设备的项目没有取得成功。 有没有办法解决这个错误?我的理解是,ES1运行不支持,按以下链接:HTTP://wwwyCypC.com?APP =论坛和ID ID=2492和;RID=45962 如有任何帮助,我们将不胜感激。 以上来自于百度翻译 以下为原文 Hello all, I've been attempting to program a CY8C3866AXI-040 ES1 which was provided with a preliminary CY8CKIT-001 REV5 PSoC development kit, and seem to have hit a dead end. The ES1 Device Revision is not selectable in PSoC Creator 1.0, and reports the following error when trying to program: "The selected debug target 'CY8C3866AXA-040 ES1' is not compatible with the project's selected device 'CY8C3866AXI-040 ES2'" I'm aware that the chip is being detected as "AXA" instead of "AXI", but selecting an "AXA" device for the project met with no success. Is there anyway to get around this error? My understanding is that the ES1 run is not supported, per the following link: http://www.cypress.com/?app=forum&id=2492&rID=45962 Any help would be appreciated. |
那是一块废弃的硅片。请将您的联系方式creator_comforts@cypress.com我会看到它,我们给你一个新的模块生产硅上。
有没有收费但我会要求你把旧的…! ——MGS 以上来自于百度翻译 以下为原文 That's an obsolete piece of silicon. Please email your contact details to creator_comforts@cypress.com and I'll see to it that we get you a new module with production silicon on it. There's no charge but I will ask you to blendthe old one...! -- mgs |
741个成员聚集在这个小组
加入小组2002 浏览 1 评论
1761 浏览 1 评论
3545 浏览 1 评论
1696 浏览 6 评论
1466 浏览 1 评论
273浏览 2评论
170浏览 2评论
355浏览 2评论
299浏览 2评论
487浏览 2评论
GMT+8, 2024-9-20 17:56 , Processed in 0.557104 second(s), Total 45, Slave 40 queries .
