使用PB1将tiM14 REMAP过来,代码如下 RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO, ENABLE); RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB,ENABLE); RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM14, ENABLE); GPIO_PinRemapConfig(GPIO_Remap_TIM14,ENABLE); GPIO_InitTypeDef GPIO_InitStructure; /* TIM4_CH1 pin (PB.06) configuration */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; RETAILMSG(DBG_INFO,("BEEP_GPIO_Configuration enablernrn")); GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(GPIOB, &GPIO_InitStructure); TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure; TIM_OCInitTypeDef TIM_OCInitStructure; /* Compute the value to be set in ARR regiter to generate signal frequency at 17.57 Khz */ BeepTimerPeriod = (SystemCoreClock / (24000000) ) - 1; /* Compute CCR1 value to generate a duty cycle at 50% for channel 1 and 1N */ // BeepChannel1Pulse = (uint16_t) (((uint32_t) 1 * (BeepTimerPeriod - 1)) / 2); /* Time Base configuration */ TIM_TimeBaseStructure.TIM_Period = 655; TIM_TimeBaseStructure.TIM_Prescaler = BeepTimerPeriod; TIM_TimeBaseStructure.TIM_ClockDivision = 0; TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; TIM_TimeBaseInit(TIM14, &TIM_TimeBaseStructure); /* Channel 1, 2,3 and 4 Configuration in PWM mode */ TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1; TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable; TIM_OCInitStructure.TIM_Pulse = 333; TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High; TIM_OC1Init(TIM14, &TIM_OCInitStructure); TIM_OC1PreloadConfig(TIM14, TIM_OCPreload_Enable); TIM_ARRPreloadConfig(TIM14, ENABLE); RETAILMSG(DBG_INFO,("TIM14 enablernrn")); /* TIM1 counter enable */ TIM_Cmd(TIM14, ENABLE); 请大神协助,与参考代码对比了好多次,都没看出问题。 |
5个回答
仿真调试吧。时钟和一些初始化模式。
在示波器看了吗?。。
你是将PB1 REMAP的?要想验证程序,可以先不用REMAP,直接用对应的口看看能不能输出波形,然后再REMAP看看。可以用示波器或逻辑分析仪看看。
在线调试一下,看看会不会是硬件上的问题~~
分享个程序看下:
1999 浏览 0 评论
STM32配合可编程加密芯片SMEC88ST的防抄板加密方案设计
1202 浏览 0 评论
2759 浏览 1 评论
AD7686芯片不传输数据给STM32,但是手按住就会有数据。
2534 浏览 3 评论
5216 浏览 0 评论
GMT+8, 2025-1-11 13:55 , Processed in 0.435142 second(s), Total 48, Slave 43 queries .
