扫一扫,分享给好友
我正在为Drexel大学的一个研究项目工作,我想知道XCR3032XL 32 Macrocell CPLD的功耗数据,以及是否已经发布了该芯片的任何更新,相同但功率更高的版本。
过去几年。 据我所知,这些信息未在数据表中列出。 如果没有详细信息,我至少想了解功耗的最小和最大限制。 以上来自于谷歌翻译 以下为原文 I'm working on a research project for Drexel University, and I would like to know the power dissipation data for the XCR3032XL 32 Macrocell CPLD, as wel as whether any newer, identical, but more power-efficient versions of this chip have been released in the past several years. As far as I can tell, this information is not listed in the datasheet. If detailed information is not available, I would at least like to know the minimum and maximum limits for power dissipation. |
在xapp317(http://www.xilinx.com/support/documentation/application_notes/xapp317.pdf)之后,帮助估算CoolRunner设备的功耗。
您可以使用此xapp来估算设计的功耗。 希望能帮助到你。 _______________________________________________如果有助于解决您的查询,请将此帖子标记为“接受为解决方案”。 因此,它将有助于其他论坛用户直接参考答案。如果您认为该信息有用且面向答复,请给予此帖子称赞。 以上来自于谷歌翻译 以下为原文 Following xapp317 (http://www.xilinx.com/support/documentation/application_notes/xapp317.pdf) helps estimate power for CoolRunner devices. You can use this xapp to estimate the power consumption for your design. Hope it helps. ________________________________________________ Please mark this post as an "Accept as solution" in case if it helped to resolve your query. So that it will help to other forum users to directly refer to the answer. Give kudos to this post in case if you think the information is useful and reply oriented. |
2522 浏览 7 评论
2885 浏览 4 评论
2341 浏览 9 评论
3439 浏览 0 评论
2524 浏览 15 评论
2682浏览 1评论
675浏览 1评论
539浏览 1评论
827浏览 0评论
GMT+8, 2025-3-10 22:13 , Processed in 1.364647 second(s), Total 74, Slave 58 queries .
