亲爱的,由于应用,我想测量PA *的两个端口的实时* S参数。
原理图在附件中勾勒出来。 -----我使用的仪器是PNA-X N5247A,我的选项如下:-----选项详情N5247A-4004端口,双源N5247A-419增加功率范围和偏置三通到4端口 分析仪N5247A-423将内部组合器和机械开关添加到4端口分析仪N5247A-080频率偏移测量N5247A-460集成真模式激励应用N4697F柔性电缆套件,1.85 mm N4694A N4694A电子校准模块,10 MHz至67 GHz,1.85 mm,2 -port N4691B电子校准模块,300 kHz至26.5 GHz,3.5 mm,2端口-----我的问题如下:1。如果我还想使用PNA-X的校准套件,我可以更换 定向耦合器*在PNA-X *内部带有*外部*定向耦合器?2。如果我可以绕过内部定向耦合器,校准程序是否需要重写? 3.我可以正常询问校准程序重写需要多长时间? 几天,几周甚至更长? 4.是否有关于重写校准程序的应用笔记或文件? 以上来自于谷歌翻译 以下为原文 Dear, Due to the application, I want to measure the real time *S-parameter of the two ports of PA*. The schematic is sketched in the attachment. ----- The instrument I use is PNA-X N5247A, the options I have is as following: ----- Options Details N5247A-400 4 ports, dual source N5247A-419 Add extended power range and bias-tees to 4 port analyzer N5247A-423 Add internal combiner and mechanical switches to 4-port analyzer N5247A-080 Frequency offset measurements N5247A-460 Integrated true-mode stimulus application N4697F Flexible Cable Set, 1.85 mm N4694A N4694A Electronic Calibration Module, 10 MHz to 67 GHz, 1.85 mm, 2-port N4691B Electronic Calibration Module, 300 kHz to 26.5 GHz, 3.5 mm, 2-port ----- My questions are as following: 1. If I want to still use the calibration set of PNA-X, can I replace the directional couplers *inside the PNA-X* with the *external* directional couplers? 2. If I could bypass the inside directional couplers, is the calibration routine need to be rewritten? 3. Can I ask normally how long the calibrating routine rewriting will take? Days, weeks or even more? 4. Are there any application notes or documents about the rewriting of calibrating routine? 附件
> {quote:title = elberlee写道:} {quote}>我的问题如下:> 1.如果我还想使用PNA-X的校准套件,我可以更换PNA-X内的定向耦合器*
使用*外部*定向耦合器?> 2.如果我可以绕过内部定向耦合器,校准程序是否需要重写? > 3.我能否正常询问校准程序重写需要多长时间? 几天,几周甚至更长? > 4.是否有关于重写校准程序的应用说明或文件? 1-是2-否3-见2 4-否,因为无需重新编写校准程序。 然而,有关使用PNA进行高功率测量的应用笔记:PNA - 放大器 - 使用安捷伦非线性矢量网络分析仪进行高功率测试(1408-10)高功率放大器测量AN 1408-19 以上来自于谷歌翻译 以下为原文 > {quote:title=elberlee wrote:}{quote} > My questions are as following: > 1. If I want to still use the calibration set of PNA-X, can I replace the directional couplers *inside the PNA-X* with the *external* directional couplers? > 2. If I could bypass the inside directional couplers, is the calibration routine need to be rewritten? > 3. Can I ask normally how long the calibrating routine rewriting will take? Days, weeks or even more? > 4. Are there any application notes or documents about the rewriting of calibrating routine? 1- Yes 2- No 3- See 2 4- No, since there is no need to re-write the calibration routine. However, there are app notes about making high power measurements with the PNA: PNA - Amplifier - High-Power Testing (1408-10) High Power Amplifier Measurements Using Agilent's Nonlinear Vector Network Analyzers AN 1408-19 |
1342 浏览 0 评论
2400 浏览 1 评论
2224 浏览 1 评论
2088 浏览 5 评论
2980 浏览 3 评论
1270浏览 1评论
788浏览 0评论
1062浏览 0评论
1342浏览 0评论
GMT+8, 2025-1-23 03:25 , Processed in 1.253653 second(s), Total 77, Slave 61 queries .
