你好,
我只是想知道哪个版本的XILINX ISE支持XQ4013E,因为我无法在xilinx ISE的新版本中找到它。如此,请提供xilinx版本的链接。请帮助我。 以上来自于谷歌翻译 以下为原文 hello, i just wanted to know which version of XILINX ISE supported the XQ4013E as i couldnt find it in the newer versions of xilinx ISE.If so please provide me the link for the xilinx version also.please help me. |
4个回答
嗨,
ISE 4.1i支持4000系列设备。 您可以从链接-http://www.xilinx.com/webpack/classics/spartan_4k/index.htm下载它。 谢谢,AnirudhPS:请将此标记作为答案,以防它有助于解决您的问题。如果帖子引导您找到解决方案,请给予赞誉。 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Hi, The ISE 4.1i had the support for the 4000 series devices. You can download it from the link - http://www.xilinx.com/webpack/classics/spartan_4k/index.htm. Thanks, Anirudh PS: Please MARK this as an answer in case it helped resolve your query.Give kudos in case the post guided you to a solution.View solution in original post |
嗨,
ISE 4.1i支持4000系列设备。 您可以从链接-http://www.xilinx.com/webpack/classics/spartan_4k/index.htm下载它。 谢谢,AnirudhPS:请将此标记作为答案,以防它有助于解决您的问题。如果帖子引导您找到解决方案,请给予赞誉。 以上来自于谷歌翻译 以下为原文 Hi, The ISE 4.1i had the support for the 4000 series devices. You can download it from the link - http://www.xilinx.com/webpack/classics/spartan_4k/index.htm. Thanks, Anirudh PS: Please MARK this as an answer in case it helped resolve your query.Give kudos in case the post guided you to a solution. |
嗨,
所有其他旧版本的ISE也可以从链接中找到-http://www.xilinx.com/webpack/classics/wpclassic/index.htm 谢谢,AnirudhPS:请将此标记作为答案,以防它有助于解决您的问题。如果帖子引导您找到解决方案,请给予赞誉。 以上来自于谷歌翻译 以下为原文 Hi, All other older versions of ISE can also be found from the link -http://www.xilinx.com/webpack/classics/wpclassic/index.htm Thanks, Anirudh PS: Please MARK this as an answer in case it helped resolve your query.Give kudos in case the post guided you to a solution. |
2474 浏览 7 评论
2860 浏览 4 评论
2321 浏览 9 评论
3406 浏览 0 评论
2502 浏览 15 评论
2154浏览 1评论
644浏览 1评论
503浏览 1评论
2054浏览 0评论
783浏览 0评论
GMT+8, 2025-2-2 23:02 , Processed in 1.199207 second(s), Total 80, Slave 64 queries .
