您好,我们计划在twozynq 7045boards之间创建一个1Gbps的链接,
我们希望tousea通过SMA连接器的两个laneaurora接口。 我们想知道对于1Gbps Aurora和2个串行通道(大约500Mbps /通道)的同轴电缆,5米长是否太长。 有没有人创建与极光的长同轴链接? 假设没有任何类电缆型的错误恢复实现,这是我应该期望与此拓扑结构的可靠链接的最大长度? 非常感谢。 以上来自于谷歌翻译 以下为原文 Hello, we are planning on creating a 1Gbps link between two zynq 7045 boards, we want to use a two lane aurora interface through the SMA connectors. we are wondering if 5m long is too much for those coaxial cables for a 1Gbps Aurora with 2 serial lanes (that would be about 500Mbps/lane). have any of you created long coaxial links with aurora? which is the maximum length I should expect for a reliable link with this topology supposing no kind of error recovery implementation? thank you so much. |
嗨,
请注意,您可以进行IBERT仿真外部环回测试,该测试应测试硬件以查看是否发生了链接。 这是iBERT GTX的文档-http://www.xilinx.com/support/documentation/ip_documentation/chipscope_ibert_kintex7_gtx/v2_01_a/chipscope_ibert_kintex7_gtx.pdf 此指南也应该有所帮助-http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_7/chipscope_pro_sw_cores_ug029.pdf 谢谢,AnirudhPS:请将此标记作为答案,以防它有助于解决您的问题。如果帖子引导您找到解决方案,请给予赞誉。 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Hi, Please note that you can do IBERT simulation external loopback test which should test the hardware to see if the link up happens. This is the documentation of iBERT GTX - http://www.xilinx.com/support/documentation/ip_documentation/chipscope_ibert_kintex7_gtx/v2_01_a/chipscope_ibert_kintex7_gtx.pdf Also this guide should help - http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_7/chipscope_pro_sw_cores_ug029.pdf Thanks, Anirudh PS: Please MARK this as an answer in case it helped resolve your query.Give kudos in case the post guided you to a solution.View solution in original post |
2512 浏览 7 评论
2881 浏览 4 评论
2338 浏览 9 评论
3431 浏览 0 评论
2519 浏览 15 评论
2629浏览 1评论
671浏览 1评论
536浏览 1评论
822浏览 0评论
GMT+8, 2025-3-7 07:14 , Processed in 1.309815 second(s), Total 75, Slave 59 queries .
