扫一扫,分享给好友
大家好,
我试图通过pmod打开LED。 但它不起作用。 我正在使用nexys3板。 这是verilog代码: 模块TestWheelDriver(输出ain1,ain2); 分配ain1 = 1'b1; 分配ain2 = 1'b0; endmodule 这是ucf文件中我在JA上更改引脚连接的部分。 ## JANET“ain1”LOC =“T12”| IOSTANDARD =“LVCMOS33”; #Bank = 2,Pin name = IO_L19P,Sch name = JA1NET“ain2”LOC =“V12”| IOSTANDARD =“LVCMOS33”; #Bank = 2,Pin name = IO_L19N,Sch name = JA2 我有两条线连接到JA上的引脚1和引脚2。 这些电线通过490欧姆电阻连接到LED。 我预计会开启。 但它没有开启。 请任何人都可以帮助我理解为什么这不起作用以及如何使其工作。 以上来自于谷歌翻译 以下为原文 Hi All, I am trying to turn on an LED via pmod. but it is not working. i am using nexys3 board. Here is verilog code: module TestWheelDriver( output ain1, ain2 ); assign ain1 = 1'b1; assign ain2 = 1'b0; endmodule Here is the part of ucf file where i change pin connection on JA. ##JA NET "ain1" LOC = "T12" | IOSTANDARD = "LVCMOS33"; #Bank = 2, Pin name = IO_L19P, Sch name = JA1 NET "ain2" LOC = "V12" | IOSTANDARD = "LVCMOS33"; #Bank = 2, Pin name = IO_L19N, Sch name = JA2 i have two wires connected to pin 1 and pin 2 on JA. these wires go to LED via 490 ohm resistor. i expected led to turn on. but it is not turning on. please can anyone help me understand why this is not working and how to make it work. |
嗨,这篇文章似乎是http://forums.xilinx.com/t5/3rd-Party-Other-Boards-and-Kits/turning-on-led-from-pmod-on-nexys3/mp的重复帖子
/ 471442请避免重复发帖。 谢谢,维杰----------------------------------------------- ---------------------------------------------请将帖子标记为 一个答案“接受为解决方案”,以防它有助于解决您的查询。如果一个帖子引导到解决方案,请给予赞誉。 以上来自于谷歌翻译 以下为原文 Hi, This post seems to be a duplicate post to http://forums.xilinx.com/t5/3rd-Party-Other-Boards-and-Kits/turning-on-led-from-pmod-on-nexys3/m-p/471442 Please avoid duplicate posts.Thanks,Vijay -------------------------------------------------------------------------------------------- Please mark the post as an answer "Accept as solution" in case it helped resolve your query. Give kudos in case a post in case it guided to the solution. |
2501 浏览 7 评论
2871 浏览 4 评论
2330 浏览 9 评论
3424 浏览 0 评论
2512 浏览 15 评论
2456浏览 1评论
660浏览 1评论
521浏览 1评论
801浏览 0评论
GMT+8, 2025-2-24 22:19 , Processed in 1.163079 second(s), Total 74, Slave 58 queries .
