从数据表''..这种不平衡是使用电荷积分来测量的,以响应施加到电容器的电压脉冲。''我想知道这种测量的速率是多少。输出给用户的最大数据速率为1 kHz。这意味着在IC内部执行的ADC测量必须达到更高的速率。是否可以知道该内部ADC的采样频率以及所使用的ADC类型?
是否提到了ADC类型的集成ADC,因为提到了“电荷积分”?在这些方面需要更详细的解释。请帮忙.. https://community.st.com/tags♯/?tags=h3lis331dl%20working htthttps://community.st.com/tags♯/?tags=h3lis331dl #h3lis331dl-working#h3lis331dl 以上来自于谷歌翻译 以下为原文 From the datasheet ''..This imbalance is measured using charge integration in response to a voltage pulse applied to the capacitor.'' I would want to know at what rate this measurement is done. The maximum data rate of output to the user is 1 kHz. Which means ADC measurements performed must be at an higher rate inside the IC. Is it possible to know the sampling frequency of this internal ADC and also the type of ADC used? Is the type of ADC used integration ADC since 'charge integration' is mentioned? More detailed explanation is required in these aspects. Please help.. https://community.st.com/tags♯/?tags=h3lis331dl%20working ‌ https://community.st.com/tags♯/?tags=h3lis331dl #h3lis331dl-working #h3lis331dl |
2821 浏览 1 评论
3262 浏览 1 评论
1838 浏览 1 评论
3687 浏览 6 评论
6091 浏览 21 评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
391浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
481浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
312浏览 2评论
使用STM32F407VET6的USB2.0功能,发现ctl后芯片无数据返回,是什么原因可能导致的呢?
228浏览 2评论
用STM32G431开发工程,1.50版本的Package包文件无法输出项目工程
333浏览 2评论
GMT+8, 2025-2-1 06:12 , Processed in 0.877145 second(s), Total 44, Slave 39 queries .
