电子发烧友论坛|
您好,我正在尝试使用labview从PXA捕获IQ样本(我可以使用Labview下载它们)。
我的来源是PSG,产生数字调制(4QAM或BPSK)。 关键是,如果我使用Basic-> IQ Waveform-> Display-> I / Q Waveform设置PXA,我就可以区分样本。 我正在使用示波器来监视PSG中BNC输出的de Q样本。 所以我实际上可以看到这些位。 然而,代表I和Q的PXA中的蓝色和黄色线不是静止的。 它们应该从触发器到触发器同样如同PN23序列一直重复的范围内发生的那样。 当我将样本下载到labview并绘制IQ样本时,我发现星座一直在旋转。 它永远不会。 对此有何解释? 谢谢! Òscar编辑:oscar.monerris于2012年5月31日上午8:06 以上来自于谷歌翻译 以下为原文 Hello, I'm trying to capture IQ samples from a PXA using Labview (I can download them with Labview). My source is a PSG generating a digital modulation (4QAM or BPSK). The point is that, if I set the PXA using Basic->IQ Waveform->Display->I/Q Waveform I'm able to distinguish the samples. I'm using an scope to monitor de Q samples form the BNC output in the PSG. So I can actually see the bits. Nevertheless, the blue and yellow lines in the PXA representing I and Q are not still. They should the same be from trigger to trigger as happens in the scope given that the PN23 sequence repeats all the time. When I download the samples to labview and plot the IQ samples I see that the constellation spins all the time. It's never still. Any explanation on this? Thank you! Òscar Edited by: oscar.monerris on May 31, 2012 8:06 AM |
嗨奥斯卡 - 你看到的问题可能是因为IF Gain设置为“Autorange”。
自动量程是早期PXA SW的默认值,但后来在后来的SW中更改为默认为低增益,这解决了问题。 早期的PXA SW Rev A.8.54或更早的SW有这个问题。 SW A.10.04或更新版本解决了这个问题。 但是,用户可以通过进入I / Q分析仪模式手动选择自动量程,按:Meas Setup,More,Advanced,More,IF Gain并手动选择Autorange。 您可以使用此键序列选择低增益设置,以确保您看到的问题消失。 欢迎来到安捷伦论坛 - 以上来自于谷歌翻译 以下为原文 Hi Oscar - The issue you are seeing is probably due to the fact IF Gain is set to “Autorange”. Auto range was the default with earlier PXA SW, but has since been changed in later SW to default to Low Gain, which solves the problem. Early PXA SW Rev A.8.54 or earlier SW had this problem. SW A.10.04 or newer fixes the problem. However, it is possible for the user to manually select Autorange by going to I/Q analyzer mode, press: Meas Setup, More, Advanced, More, IF Gain and manually select Autorange. You can use this key sequence to select the Low Gain setting to assure the problem you are seeing goes away. Welcome to the Agilent Forum - |
1287 浏览 0 评论
2375 浏览 1 评论
2194 浏览 1 评论
2064 浏览 5 评论
2951 浏览 3 评论
1111浏览 1评论
753浏览 0评论
926浏览 0评论
1287浏览 0评论
GMT+8, 2024-12-24 02:28 , Processed in 1.594676 second(s), Total 78, Slave 62 queries .
