我有2个配置:-TFT,带有控制器(SSD1963)的480X222像素。带控制器的800×480像素的TFT(SSD1963)。480X22使用PIC32 MZ,I可以从外部闪存读取RAM并写入LCD,因为PIC32 MZ具有512K字节的RAM,全屏需要261120字节,但具有800×480。它需要768000个字节,那么什么是优化速度的最佳方法?1。-读取半字节(384000)并写入TFT,然后读取剩余的384000个字节并再次写入TFT。2。-从FLASH读取1个像素并写入TFT循环,直到完成全屏。也许还有另一种方法比这2最佳。感谢任何帮助。
以上来自于百度翻译 以下为原文 I have 2 configs: - TFT with 480x272 pixels with controller (SSD1963). - TFT with 800x480 pixels with controller (SSD1963). With the 480x272 using a PIC32MZ I can read from external flash to RAM and write to LCD because PIC32MZ has 512Kbyte of RAM and a full screen needs 261120 bytes, but with 800x480 it needs 768000 bytes so what could be the best method for optimized speed? 1.- Read half of bytes(384000) and write to TFT then read the rest 384000 bytes and write again to TFT. 2.- Read 1 pixel from flash and write to TFT cyclic until full screen is done. Maybe there is another method that is best than this 2. Any help appreciated. Thanks. Francisco. |
换用RA8889的液晶控制IC就可以了,它有DMA功能,可直接取FLASH的数据来显示,不用经过MCU来读,速度也更快,MCU发些简单的指令就可以了
5242 浏览 9 评论
2031 浏览 8 评论
1955 浏览 10 评论
3207 浏览 3 评论
2256 浏览 5 评论
778浏览 1评论
669浏览 1评论
596浏览 1评论
678浏览 0评论
577浏览 0评论
GMT+8, 2024-12-23 21:06 , Processed in 1.151674 second(s), Total 49, Slave 43 queries .
