扫一扫,分享给好友
我有一个FX2配置为从FIFO(我加载固件为奴隶在应用笔记EP6737)。我试着从EP6的外部主机读取CyStand数据,一切都正常工作。现在我的问题是:在一个用户应用程序(用C++编写)中,我必须在文件上写入从EP6到达的数据。在实践中,我读取每个字节,看看是否有一个特定的值,因为一个特定的配置的到来,我不得不停止阅读。我在套装USB应用程序StuffER的示例项目中发现,我能帮助的唯一一个?没有其他示例代码吗?非常感谢。
以上来自于百度翻译 以下为原文 I have a FX2 configured as a SLAVE FIFO (I loaded the firmware for slave in the application note EP63787). I tried to read through CYCONSOLE data from an external master from EP6 and everything is working correctly. Now my problem is this: in a user application (written in C++) I have to write the data that arrives from EP6 on a file. In practice, I read every byte to see if a particular value, since the arrival of a particular configuration I have to stop reading. I found in the sample projects of Suite USB the application Streamer, is the only one I can help? There is no other example code? Thank you very much. |
3个回答
我的数据传输速率有问题,我只能得到10kb/s,使用CopiasasCuiGET多少?
以上来自于百度翻译 以下为原文 I'm having problems with data transfer rate, I can only get 10kb/sec, using CyAPIas how much can i get? |
我附上了我修改的拖缆.h文件。
拉链 6.3 K 以上来自于百度翻译 以下为原文 I've attached the Streamer.h file modified by me.
你好,
我相信问题不会是CyAPI,因为我们可以达到速度,如USB规范所支持的,例如在43-45 Mbps的大端点。固件会出现一些问题。 检查外部主机是否以恒定的速率提供足够高的数据。Aso实现好的SPEDS使用自动模式。 -SUB 以上来自于百度翻译 以下为原文 Hi, I believe the problem would not be the cyapi as we can acheieve speeds as supported by u*** spec for example around 43-45 MBps with bulk endpoints.There would be some problem in the firmware. Check whether the external master is supplying data at a constant rate which is high enough.Aso to achieve good sppeds use AUTO mode. -Shub |
754个成员聚集在这个小组
加入小组2106 浏览 1 评论
1853 浏览 1 评论
3671 浏览 1 评论
1788 浏览 6 评论
1536 浏览 1 评论
572浏览 2评论
424浏览 2评论
438浏览 2评论
386浏览 2评论
916浏览 2评论
GMT+8, 2024-12-25 09:26 , Processed in 0.877427 second(s), Total 82, Slave 66 queries .
