嗨,
我正在使用planAhead 14.4,在映射过程中我收到以下错误: FATAL_ERROR:Map:mapbafragmast.c:1981:1.68 - INITSTATE 0的长度不是4的倍数。 流程将终止。 有关此问题的威廉希尔官方网站 支持,请通过http://www.xilinx.com/support连接此项目打开WebCase。 我不知道这是什么意思。 谁能告诉我这是什么以及如何解决这个问题? 我认为它可能与我设置的一些MAP标志有关。 谢谢, --Rudy 以上来自于谷歌翻译 以下为原文 Hi, I am using planAhead 14.4, and during the map process I get the following error: FATAL_ERROR:Map:mapbafragmast.c:1981:1.68 - The length of INITSTATE 0 is not a multiple of four. Process will terminate. For technical support on this issue, please open a WebCase with this project attached at http://www.xilinx.com/support. I have no idea what does this mean. Can someone tell me what this is and how to get around this? I think it might be related to some of the MAP flags that I set. Thanks, --Rudy |
3个回答
嗨,你能分享实施日志吗?问候,Achutha
-------------------------------------------------- -------------------------------------------请注意 - 请标记答案 如果提供的信息有用,请“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢Kudos .------------------------ -------------------------------------------------- -------------- 以上来自于谷歌翻译 以下为原文 Hi , Can you share the implementation log? Regards, Achutha--------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------- |
嗨鲁迪,
同一消息几乎没有致命错误,这些错误在最新版本中得到修复。 它与RAM256X1S相关,具有未填充的INITSTATE = 0属性,该属性应由工具自动设置。 你能检查一下你的设计中是否有分布式RAM吗? 作为一个工作,您可以专门设置INIT值或尝试最新版本? 以上来自于谷歌翻译 以下为原文 Hi Rudy, There were few fatal errors with the same message and these were fixed in latest version. It was related to a RAM256X1S with an unpadded INITSTATE = 0 property which should automatically be set by tools. Can you check if there are any distributed RAMs in your design? As a workaorund, you could specifically set the INIT values or try a latest version? |
嗨,
你能告诉我如何设置INIT值吗? 谢谢, --Rudy 以上来自于谷歌翻译 以下为原文 Hi, Would you please tell me how to set the INIT values ? Thanks, --Rudy |
2522 浏览 7 评论
2885 浏览 4 评论
2341 浏览 9 评论
3439 浏览 0 评论
2524 浏览 15 评论
2679浏览 1评论
675浏览 1评论
539浏览 1评论
827浏览 0评论
GMT+8, 2025-3-10 18:28 , Processed in 1.490955 second(s), Total 78, Slave 62 queries .
