扫一扫,分享给好友
我试图建立这个应用笔记中概述的电路。不幸的是,我没有取得成功。我不能让芯片产生任何东西到开关电路。我们已经修改了相同的代码,在PSoC3的评估板上工作,并且在那里已经成功,但是当适应这个电路时,它什么也不做。
有没有人能成功地产生这个电路,可能有一些指针或建议? 以上来自于百度翻译 以下为原文 I've attempted to build the circuit outlined in this application note. Unfortunately I haven't been very successful. I am unable to get the chip to generate anything into the switching circuit. We've adapted the same code to work on the evaluation board for the psoc3 and have been successful there, but when adapting to this circuit, it does nothing. Is there anyone who has successfully been able to produce this circuit that might have some pointers or suggestions? |
嗨,Pedricus,
你能在PSoC软件下发布你的查询吗?& PST设计软件,因为你的查询与照明产品有关? 当做, 基肖尔 以上来自于百度翻译 以下为原文 Hi Pedricus, Can you please post your query under PSoC Software -> PSoC Designer Software as your query is relating to Lighting Products? Regards, Kishore. |
754个成员聚集在这个小组
加入小组2110 浏览 1 评论
1858 浏览 1 评论
3673 浏览 1 评论
1791 浏览 6 评论
1540 浏览 1 评论
575浏览 2评论
428浏览 2评论
440浏览 2评论
390浏览 2评论
922浏览 2评论
GMT+8, 2024-12-26 22:57 , Processed in 1.573255 second(s), Total 99, Slave 83 queries .
