大家好,
在一个月内,我将合并到一家公司的项目中,该公司询问我是否必须购买任何Xilinx软件。 我们将使用ML605评估板,其中我可以阅读的内容包括:ISE Design Suite:Logic Edition。 (器件锁定到Virtex-6 LX240T FPGA)。 我无法在Xilinx网站上找到此Logic Edition中包含的程序和许可证。 我将使用MicroBlaze,我将需要XPS和SDK。 有谁知道我是否能够将这两个程序与这个Logic Edition一起使用? 我们应该购买ISE D.S. Embedded Edition吗? 非常感谢你。 亲切的问候。 伊格纳西奥莫雷诺。 以上来自于谷歌翻译 以下为原文 Hi all, in one month I am incorporating to a project in a company which is asking me if they have to buy any Xilinx software. We are going to use ML605 Evaluation Board, in which specs I can read that it contains: ISE Design Suite: Logic Edition. (Device-locked to the Virtex-6 LX240T FPGA). I cannot find across Xilinx website the programs and licenses that are included in this Logic Edition. I am going to work with MicroBlaze and I will need XPS and SDK. Does anyone know if I will be able to use both programs with this Logic Edition? Should we buy a ISE D.S. Embedded Edition instead? Thanks you very much. Kind regards. Ignacio Moreno. |
3个回答
HiNo,您不能将XPS和SDK与逻辑版一起使用。
您需要嵌入式版本或独立的EDK许可证。谢谢,Vinay -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Hi No, you cannot use XPS and SDK with logic edition. You need Embedded edition or standalone EDK license. Thanks, Vinay-------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution.View solution in original post |
嗨,请查看http://www.xilinx.com/publications/matrix/Software_matrix.pdf
谢谢,维杰----------------------------------------------- ---------------------------------------------请将帖子标记为 一个答案“接受为解决方案”,以防它有助于解决您的查询。如果一个帖子引导到解决方案,请给予赞誉。 以上来自于谷歌翻译 以下为原文 Hi, Please check http://www.xilinx.com/publications/matrix/Software_matrix.pdfThanks,Vijay -------------------------------------------------------------------------------------------- Please mark the post as an answer "Accept as solution" in case it helped resolve your query. Give kudos in case a post in case it guided to the solution. |
您需要嵌入式版本或独立的EDK许可证。谢谢,Vinay -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hi No, you cannot use XPS and SDK with logic edition. You need Embedded edition or standalone EDK license. Thanks, Vinay-------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
2702 浏览 7 评论
3018 浏览 4 评论
2435 浏览 9 评论
3546 浏览 0 评论
2639 浏览 15 评论
3431浏览 1评论
843浏览 1评论
703浏览 1评论
GMT+8, 2025-7-12 12:48 , Processed in 1.096405 second(s), Total 51, Slave 45 queries .
