有没有人配置了SD卡的SD卡使用和谐的WiFi火?我不确定我的配置是正确的,如果有可能的话,我希望有人能和他们分享。更具体地说,我将SD卡集成到TCP/IP协议栈中,如果有人做了任何工作的话。
以上来自于百度翻译 以下为原文 Has anyone configured the SD card for the chipKIT WiFire using HARMony? I'm not sure my configurations are correct and would love for someone to share theirs if they could. More specifically I'm integrating the SD card into the TCP/IP stack, If anyone's done any work on that. Using current full release of MPLAB and V2.01B Harmony. |
5个回答
有一个TCP/IP演示使用SD卡驱动程序作为协调标准演示的一部分被释放。它位于:AppTCPIWebSyVeluxSDCARIDFATFS。您可以将此作为项目的参考。
以上来自于百度翻译 以下为原文 There is a TCP/IP demo that makes use of the SDCARD driver which is released as part of the Harmony standard demos. It is located at: appstcpipweb_server_sdcard_fatfs. You could use this as a reference for your project. |
我正在努力让SD卡挂载并使用正常的读写功能。我使用SDCARDFARFAXJUNLYLE磁盘示例,不能让SD卡挂载。我已经包含了下面的和声配置。如果有人看到任何错误,或者有任何建议,那将是巨大的。帮助。
以上来自于百度翻译 以下为原文 I am working on simply getting the SD card to mount and use normal read write functions. I'm using the sdcard_far_single_disk example and can not get the SD card to mount. I've included my harmony configuration below. If anyone see's anything wrong with, or has any suggestions, it that would be a huge help. Attachment(s) pic32mz_ef_sk_int_dyn.txt (134.62 KB) - downloaded 107 times |
如果媒体状态被指示为分离,则挂载通常失败。这可能意味着SD卡初始化没有通过。确保SPI接口正确设置,PIN映射正确。
以上来自于百度翻译 以下为原文 Mount usually fails if the media status is indicated as detached. This could probably mean that the SD Card initialization did not go through. Ensure that the SPI interface is set up properly and the pin mappings are correct. |
据我所知,引脚确实设置正确,以及SPI驱动器。我已经包含了相关信息的图片。还注意到我正在使用MicroSD卡。Microchip WiFi火有内置的微卡读卡器,它连接到SPI 3。
以上来自于百度翻译 以下为原文 As far As I am aware the pins are indeed set up correctly as well as the SPI driver. I've included pictures of the relevant information. Also note I am using a microSD card. The Microchip Wifire has a built in MicroSDcard reader that is connected to SPI 3. Attached Image(s) |
对于任何人谁发现,我发现我没有相位和时钟模式正确配置的微型SD卡我正在使用。我已经打开了一个单独的线程,详细说明了我在同一个示例代码中遇到的其他问题。当它工作时,我会在这里发布完整的和谐配置。
以上来自于百度翻译 以下为原文 For anyone who come across the post I discovered I did not have the phase and Clock Mode properly configured for the micro SD card I was using. I've opened a separate thread detailing other problems I've come across in the same example code. I will post the full Harmony Configuration here when it works |
5064 浏览 9 评论
1945 浏览 8 评论
1879 浏览 10 评论
3104 浏览 3 评论
2175 浏览 5 评论
615浏览 1评论
484浏览 1评论
344浏览 1评论
515浏览 0评论
422浏览 0评论
GMT+8, 2024-9-20 21:21 , Processed in 1.266938 second(s), Total 86, Slave 70 queries .
