在adc_delsig手册页面有一个快速滤波器转换型相关说明:
注意护理时应切换信号之间的ADC转换。无论是切换输入迅速与硬件控制或停止ADC同时切换输入之后,新的信号已经连接到ADC启动ADC。如果不这样做会导致ADC结果信号之间的串扰。 没有人知道作者想说“快硬件开关”? 当做 罗伯特 以上来自于百度翻译 以下为原文 In ADC_DelSig manual page 4 there is a note related to Fast Filter conversion type: Note Care should be taken when switching signals between ADC conversions. Either switch the input quickly with hardware control or Stop the ADC while switching the input then restart the ADC after the new signal has been connected to the ADC. Failure to do this may result in crosstalk between signals in the ADC results. Does anyone know what Author had in mind saying "fast hardware switching"? Regards Robert |
可以使用AMUX(模拟多路复用器组件)来完成不同信道之间的切换。有一个硬件多路复用器组件,它在输入通道之间切换。
因此,如果硬件多路复用器连接到ADCJ-Delsig,在PSoC中输入通道之间的切换可以非常快地完成。 以上来自于百度翻译 以下为原文 Switching between different channel can be done using AMUX(Analog Mux Component). There is a hardware mux component which switches between the input channels. So if the Hardware Mux is connected to ADC_Delsig, switching between input channels can be done very fast, in PSoC. |
756个成员聚集在这个小组
加入小组2122 浏览 1 评论
1864 浏览 1 评论
3680 浏览 1 评论
1800 浏览 6 评论
1543 浏览 1 评论
597浏览 2评论
445浏览 2评论
447浏览 2评论
400浏览 2评论
1079浏览 2评论
GMT+8, 2025-1-8 02:58 , Processed in 0.641715 second(s), Total 43, Slave 38 queries .
