我的项目是“使用FPGA灵活的硬件实现”......
其中包括硬件级别的实现 1.数字滤波器的FLexible规范 2.可变长度FFT算法 3.Multistandard灵活的滤波器组 4.灵活的可变速率模拟到数字转换器...... 我的主管愿意给我买一块FPGA板.....我需要你告诉我哪个FPGA板适合这个项目,因为我必须实现以上四个硬件...... Xylinx和Altera是FPGA的两个主要供应商,我应该选择哪一个? 以及哪种模式 这将是一个很大的帮助 因为我代表我做了研究,但我无法从中获得更多...... 期待你的指导......谢谢 以上来自于谷歌翻译 以下为原文 MY project is "flexible hardware implementation using FPGA"......which include hardware level implementation of 1. FLexible specification of digital Filters2.Variable Length FFT Algorithms3.Multistandard flexible filter banks4. Flexible and variable rate analogue to digital convertors... My supervisor is willing to buy me a FPGA board .....I need you to tell me which FPGA board will b suitable for this project considering i have to implement above four hardwares..... Xylinx and Altera are two main suppliers of FPGAs which one i should go for?and which modelit will be a great helpas i have done research on my behalf but i couldnt get more out of it... looking forward for you guidance ...thanks |
3个回答
Xilinx是FPGA的明显选择。
:-) 我不担心在这个阶段买一块板子,因为你有很多学习要做的事情。 首先下载工具的评估版本,然后开始学习设计生成的基础知识,然后使用System Generator为FFT部分提供更先进的英国威廉希尔公司网站 。 一旦掌握了设计所需的逻辑资源,您就可以选择合适的开发板,并使用满足您需求的设备。 ------您是否尝试在Google中输入问题? 如果没有,你应该在发布之前。太多结果? 尝试添加网站:www.xilinx.com 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Xilinx is the obvious choice for the FPGA. :-) I would not worry about buying a board at this stage as you have a lot of learning to do first. Start by downloading an evaluation version of the tools and start learning the basics of design generation and then the more advance design techniques with System Generator for the FFT portion. Once you get a handle on the logic resources that are needed for your designs you will then be able to select the right development board with a device that meets your needs. ------Have you tried typing your question into Google? If not you should before posting. Too many results? Try adding site:www.xilinx.comView solution in original post |
Xilinx是FPGA的明显选择。
:-) 我不担心在这个阶段买一块板子,因为你有很多学习要做的事情。 首先下载工具的评估版本,然后开始学习设计生成的基础知识,然后使用System Generator为FFT部分提供更先进的英国威廉希尔公司网站 。 一旦掌握了设计所需的逻辑资源,您就可以选择合适的开发板,并使用满足您需求的设备。 ------您是否尝试在Google中输入问题? 如果没有,你应该在发布之前。太多结果? 尝试添加网站:www.xilinx.com 以上来自于谷歌翻译 以下为原文 Xilinx is the obvious choice for the FPGA. :-) I would not worry about buying a board at this stage as you have a lot of learning to do first. Start by downloading an evaluation version of the tools and start learning the basics of design generation and then the more advance design techniques with System Generator for the FFT portion. Once you get a handle on the logic resources that are needed for your designs you will then be able to select the right development board with a device that meets your needs. ------Have you tried typing your question into Google? If not you should before posting. Too many results? Try adding site:www.xilinx.com |
看你的要求的性能还是比较高的,还是选择xilinx吧
2511 浏览 7 评论
2880 浏览 4 评论
2337 浏览 9 评论
3430 浏览 0 评论
2518 浏览 15 评论
2625浏览 1评论
670浏览 1评论
535浏览 1评论
821浏览 0评论
GMT+8, 2025-3-6 19:08 , Processed in 1.172945 second(s), Total 46, Slave 41 queries .
