亲爱的朋友们,
我有一个多锁设计。 时钟为50MHz,200MHz和400Mhz。 如果仅使用400MHz时钟并使用时钟使能产生200Mhz和50Mhz时钟域。 现在我需要将信号从一个时钟域传递到另一个时钟域。 我该怎么做才能确保其他时钟域看到这些信号。 问候 瓦里丝 以上来自于谷歌翻译 以下为原文 dear friends, I am having a multiclock design. The clocks are 50MHz, 200MHz and 400Mhz. If am using only 400MHz clock and use clock enables to generate 200Mhz and 50Mhz clock domains. Now i have a need to pass signal from one clock domain to another . What shall i do to make sure that these signals are seen by the other clock domain. regards Waris |
9个回答
我还想问一下,使用DCM进行时钟分割是否更好?
以上来自于谷歌翻译 以下为原文 I also want to ask , is it better to use DCM for clock division? |
您的原始帖子并不清楚您想要了解的内容。
请尝试改写你的问题。 ------您是否尝试在Google中输入问题? 如果没有,你应该在发布之前。太多结果? 尝试添加网站:www.xilinx.com 以上来自于谷歌翻译 以下为原文 Your original post was not clear on what you were trying to understand. Please try rephrasing your question. ------Have you tried typing your question into Google? If not you should before posting. Too many results? Try adding site:www.xilinx.com |
亲爱的mcgett,当我使用时钟启用多重锁定设计时。
我该怎么做才能确保信号从一个域传递到另一个域,例如。 正确看到50Mhz到100Mhz,反之亦然。 以上来自于谷歌翻译 以下为原文 Dear mcgett, When i use clock enables for multiclock design. What shall i do to make sure that the signals passing from one domoain to another eg. 50Mhz to 100Mhz and vice versa are seen correctly. |
如果您的单时钟以400 MHz运行,并且某些寄存器上的时钟使能,每8个周期启用50 MHz,4个周期达到100 MHz,那么您应该没有问题。
为什么你认为你会遇到问题? ------您是否尝试在Google中输入问题? 如果没有,你应该在发布之前。太多结果? 尝试添加网站:www.xilinx.com 以上来自于谷歌翻译 以下为原文 If you have single clock running at 400 MHz with clock enables on some registers that are enabled every 8 cycles to get 50 MHz and 4 cycles to get 100 MHz then you should have no issues. Why do you think that you would have a problem? ------Have you tried typing your question into Google? If not you should before posting. Too many results? Try adding site:www.xilinx.com |
亲爱的mcgett,我担心从400MHz域产生的信号,并说50Mhz。
当没有50Mhz的使能时,这些信号可以由逻辑产生,例如。 与计数值为6对齐的信号。 以上来自于谷歌翻译 以下为原文 Dear mcgett, i am worried about the signal generated from 400MHz domain and going to say 50Mhz. these signals could be generated by the logic when the enable of 50Mhz is absent eg. a signal which aligns with say count value of 6 . |
您创建的逻辑必须考虑到这一点,并保留该值,直到它被接受到下一个域。
------您是否尝试在Google中输入问题? 如果没有,你应该在发布之前。太多结果? 尝试添加网站:www.xilinx.com 以上来自于谷歌翻译 以下为原文 The logic that you create must take this into account and hold the value until it has been accepted into the next domain. ------Have you tried typing your question into Google? If not you should before posting. Too many results? Try adding site:www.xilinx.com |
waris.mohammad写道:嗨,那么那些将是多周期路径。
没有。 ----------------------------是的,我这样做是为了谋生。 以上来自于谷歌翻译 以下为原文 waris.mohammad wrote:No. ----------------------------Yes, I do this for a living. |
2511 浏览 7 评论
2880 浏览 4 评论
2337 浏览 9 评论
3430 浏览 0 评论
2517 浏览 15 评论
2620浏览 1评论
670浏览 1评论
534浏览 1评论
821浏览 0评论
GMT+8, 2025-3-6 02:39 , Processed in 1.508804 second(s), Total 87, Slave 71 queries .
