扫一扫,分享给好友
嗨,
我正在使用Zedboard来测试我们的设计。 例如,我们正在尝试使用AXI_DMA,带有AXI接口的FIFO,带有AXI接口的自定义逻辑来建立设计。我们正在尝试执行简单的环回测试。 当我们进行此测试时,我们没有在AXI_DMA Rx端接收到正确的数据。为了验证自定义逻辑工作正常,我已经使用PlanAhed 14.4 / 14.6将chipscope Pro添加到我的设计中。 我们遵循了PlanAhed教程:使用Chipscope -UG677进行调试(v 14.5)以调试此问题。我们发现PlanAhead工具推断出ILA核心的多个实例,因为我们增加了标记为调试的“网络”数量。 有时,32位总线的网络最终会出现在两个不同的ILA内核(每个16位)中。 任何指针? 或者任何人都可以指出我在UISng PA其他UG677上的chipcope pro调试中的任何其他材料。 问候 钱德拉 以上来自于谷歌翻译 以下为原文 Hi , I'm using Zedboard to test our design. For example we are trying to establish a design using AXI_DMA, FIFO with AXI interface, Custom logic with AXI interface. We are trying to perform a simple loop back test. We are not receiving proper data at the AXI_DMA Rx side when we do this test. In order to verify out custom logic is working fine i had go into adding chipscope Pro into my design using PlanAhed 14.4/14.6. We had followed PlanAhed Tutorial : Debugging with Chipscope -UG677 (v 14.5) in order to debug this issue. We found that PlanAhead tool infers more than 1 instances of ILA core as we increase the number of "Nets" marked for debug. Sometimes it happens that a Nets which is 32-bit bus could end up in two different ILA cores (16 bit each). any pointers? or Can any one point me to a any other material on chipscope pro debugging in uisng PA other that UG677. regards Chandra |
嗨,
请在下面的ISE 14.4和14.6中找到所有Chipscope Pro文档的链接。 14.6-链接 14.4-链接 谢谢, 谢谢,AnirudhPS:请将此标记作为答案,以防它有助于解决您的问题。如果帖子引导您找到解决方案,请给予赞誉。 以上来自于谷歌翻译 以下为原文 Hi, Please find the links to all the Chipscope Pro documentation for ISE 14.4 and 14.6 below. 14.6 - link 14.4 - link Thanks, Thanks, Anirudh PS: Please MARK this as an answer in case it helped resolve your query.Give kudos in case the post guided you to a solution. |
嗨Chandra,
DId这个帮助? 或者仍然在寻找任何具体信息? 谢谢, 谢谢,AnirudhPS:请将此标记作为答案,以防它有助于解决您的问题。如果帖子引导您找到解决方案,请给予赞誉。 以上来自于谷歌翻译 以下为原文 Hi Chandra, DId this help? or still looking for any specific information? Thanks, Thanks, Anirudh PS: Please MARK this as an answer in case it helped resolve your query.Give kudos in case the post guided you to a solution. |
2308 浏览 7 评论
2718 浏览 4 评论
2201 浏览 9 评论
3282 浏览 0 评论
2354 浏览 15 评论
631浏览 1评论
1684浏览 1评论
443浏览 1评论
200浏览 1评论
652浏览 0评论
GMT+8, 2024-9-20 20:32 , Processed in 1.230849 second(s), Total 78, Slave 62 queries .
