嗨,
需要帮助根据图片中的物理部分提供有关日期代码信息的建议。 请查看随附的照片& 紧急建议。 谢谢。 以上来自于谷歌翻译 以下为原文 Hi, Need help to advise on the date code information base on the physical part in picture. Kindly review the attached photo & advise urgently. Thanks. |
5个回答
本文档的第415页:http://www.xilinx.com/support/documentation/user_guides/ug195.pdft这些部分是在2012年第33周制作的。
- 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用且回复的帖子。 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 per page 415 of this document: http://www.xilinx.com/support/documentation/user_guides/ug195.pdf these parts were made in 33rd week of 2012.- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented.View solution in original post |
- 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用且回复的帖子。 以上来自于谷歌翻译 以下为原文 per page 415 of this document: http://www.xilinx.com/support/documentation/user_guides/ug195.pdf these parts were made in 33rd week of 2012.- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. |
嗨,
我还有另一张图片来验证日期代码。 请指教。 谢谢。 以上来自于谷歌翻译 以下为原文 Hi, I have another picture to verify on the date code as well. Please advise. Thanks. |
再次,根据ug195,第415页,第二个数字显示2012年第37周。
以上来自于谷歌翻译 以下为原文 Again, according to ug195, page 415, the second figure shows 37th week of 2012. |
如果您要问这个问题以确定这些部件是真实的还是假的,则无法从任何照片中辨别零件是真实的还是假的。
唯一的方法是通过生产测试程序放置零件。 如果您从授权的Xilinx分销商处购买零件,那么这些零件将是真实的,但如果您以任何其他方式购买零件,那么您将承担部件假货的巨大风险。 ------您是否尝试在Google中输入问题? 如果没有,你应该在发布之前。太多结果? 尝试添加网站:www.xilinx.com 以上来自于谷歌翻译 以下为原文 If you are asking this question to determine if the parts are real or fake then it is impossible to tell from any photo if a part is real or fake. The only way to tell is to place the part through the production test program. If you buy parts from an authorized Xilinx distributors then the parts will be real, but if you are buying parts in any other way then you are taking a substantial risk that the parts are fake. ------Have you tried typing your question into Google? If not you should before posting. Too many results? Try adding site:www.xilinx.com |
2498 浏览 7 评论
2870 浏览 4 评论
2329 浏览 9 评论
3424 浏览 0 评论
2510 浏览 15 评论
2442浏览 1评论
658浏览 1评论
519浏览 1评论
2074浏览 0评论
800浏览 0评论
GMT+8, 2025-2-23 23:13 , Processed in 1.464921 second(s), Total 83, Slave 67 queries .
