尊敬的先生/女士,
我想在FPGA上实现Zigbee收发器系统。 是否可以在Spartan 3E入门套件上实施? 需要什么其他硬件设备 与FPGA接口? 我无法理解如何 继续这个项目(我是否也必须设计 协议栈)。 Plz很快回答我。 以上来自于谷歌翻译 以下为原文 Dear Sir/Madam, I want to implement Zigbee Transceiver system on FPGA. Whether it is possible to implemnt on Spartan 3E Starter kit? What are the other hardware equipments required for interfacing with FPGA ? I could not able to understand how to proceed for this project(whether i have to also design for protocol stack ). Plz answer me soon. |
你可以购买带有uart接口的zigbee收发器,即收发器和同一封装/板上的一些基带控制器,这样你只需将uart连接到fpga,这几乎是微不足道的。
寻找适合aurdino的zigbee模块。 对于fpgas来说它们也应该很容易。 - 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用且回复的帖子。 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 you can buy zigbee transceivers with a uart interface, ie a transceiver and some baseband controller in the same package/board so you only have to connect a uart to the fpga which is almost trivial. look for zigbee modules suitable for aurdino. they should be very easy for fpgas too.- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented.View solution in original post |
寻找适合aurdino的zigbee模块。 对于fpgas来说它们也应该很容易。 - 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用且回复的帖子。 以上来自于谷歌翻译 以下为原文 you can buy zigbee transceivers with a uart interface, ie a transceiver and some baseband controller in the same package/board so you only have to connect a uart to the fpga which is almost trivial. look for zigbee modules suitable for aurdino. they should be very easy for fpgas too.- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. |
2308 浏览 7 评论
2719 浏览 4 评论
2201 浏览 9 评论
3282 浏览 0 评论
2355 浏览 15 评论
633浏览 1评论
1685浏览 1评论
444浏览 1评论
203浏览 1评论
653浏览 0评论
GMT+8, 2024-9-22 04:32 , Processed in 0.905283 second(s), Total 47, Slave 42 queries .
