嗨,我知道如何导出单个原理图和布局,但我想向同事发送整个项目(包含很多原理图和布局)。
你能告诉我怎么样吗? 以上来自于谷歌翻译 以下为原文 Hi, I know how to export single schematics and layouts, but I would like to send to a colleague entire projects (containing a very high numeber of schematics and layouts). Can you tell me how? |
你没有说什么版本的ADS。
* ADS 2009U1 *或更早的存档/取消存档项目,以传输紧凑的项目存档。 为项目创建单个文件简化了将项目传输到另一个文件系统或同一文件系统上的另一个位置的过程。 归档项目* ADS 2012.08 *(适用于ADS 2011.01或更高版本)ADS提供归档一个或多个工作区,库和/或单元的功能。 该命令从打开的工作区的各种菜单启动。 启动后,向导将引导您完成整个选定项目的归档过程。 然后将这些项目复制到存档文件(* .7z)中。 然后可以轻松地与其他用户共享存档文件。 要查看存档文件,您必须使用Unarchive。 归档工作区和库 以上来自于谷歌翻译 以下为原文 You do not say what version of ADS. *ADS 2009U1* or earlier Archive/Unarchive projects to transfer a compact project archive. Creating a single file for a project simplifies transferring projects to another file system or to another location on the same file system. Archiving Projects *ADS 2012.08* (for ADS 2011.01 or later) ADS provides the ability to archive one or more workspaces, libraries, and/or cells. The command is initiated from various menus from an opened workspace. When initiated, a wizard will step you through the process to archive selected items. These items are then copied into an archive file (*.7z). The archive file can then be easily shared with other users. To view an archive file, you must use the Unarchive. Archiving Workspaces and Libraries |
1476 浏览 0 评论
2467 浏览 1 评论
2313 浏览 1 评论
2160 浏览 5 评论
3094 浏览 3 评论
1651浏览 1评论
888浏览 0评论
1476浏览 0评论
GMT+8, 2025-4-3 19:34 , Processed in 1.111395 second(s), Total 75, Slave 59 queries .
