所有其他设备规格VDD * 0.7沃(分钟)。但cy8c21334具有vdd-1,VIL = 0.8V,体积= 0.75。如果使用VDD = 3.3V逻辑高= -0.01噪声容限。另外一个装置相同的工作电压规格是VIH=3V,VIL=0.3V,VoH=VDD*0.65(2.145V)和VOL=0.6V,这与CY8C21334完全不匹配。这些边缘值逻辑H = - 0.7和逻辑L = -0.45。请给出解决方案匹配的所有其他设备。
以上来自于百度翻译 以下为原文 all other Devices specifications are Vdd*0.7 for VOH(min). But CY8C21334 having Vdd-1, Vil = 0.8V, Vol = 0.75. if operate Vdd = 3.3V, Noise margin for logic High = -0.01. And a one more device same operating voltage Specifications are Vih = 3V, Vil = 0.3V, Voh = Vdd*0.65( 2.145V) and Vol = 0.6V this is totally not matched with CY8C21334. these margin Values are logic H = -0.7 and logic L = -0.45. Please give the solution for matching all other devices. |
嗨,Karthi,
VIH=3V(min)和VIL=0.3V(max)规格对于您使用的设备似乎不是很好。这些似乎相当高和低,分别为CMOS器件逻辑电平。 但是,你很可能让它工作得很好。对于PSoC器件而言,VoH=VDD-1和VOL=0.75规格是最坏的情况,并且承担相当多的负载电流。您将注意到数据表中,这些规范对于10mA或25毫安级的电流保持正确。因此,如果引脚上的输出电流非常低,那么您可以期待更好的Voh和VoL数。我将尝试看2405年“电源管理-PSoC IO电源结构-确定VoH和VoL在部分负载”的链接到这里。 基于VDD,您可以计算设备中的电阻。然后你可以计算出需要多少输出电流,这将允许你解决你的最大/分钟VoH和VOL值。 最好的问候,本 以上来自于百度翻译 以下为原文 Hi Karthi, The Vih = 3V(min) and Vil = 0.3V(max) specs for the device you are using appear to be not very good. These seem to be pretty high and low, respectively for CMOS device logic levels. But, you can likely make it work just fine. The Voh=Vdd-1 and Vol=0.75 specs for PSOC devices are worst case and assume quite a bit of load current. You will notice in the datasheets that those specs hold true for currents on the order of 10mA or 25 mA. So, if the output current on the pins is very low, then you can expect much better Voh and Vol numbers. I would try taking a look at AN2405 "Power Management - PSoC IO Power Structure - Determining VOH and VOL at Partial Load" The link to it is here. Based on Vdd, you can calculate the resistances in your device. You can then figure out how much output current is required, and this will allow you to solve your max/min Voh and Vol values. Best regards, Ben |
756个成员聚集在这个小组
加入小组2129 浏览 1 评论
1869 浏览 1 评论
3687 浏览 1 评论
1806 浏览 6 评论
1552 浏览 1 评论
622浏览 2评论
460浏览 2评论
455浏览 2评论
408浏览 2评论
1099浏览 2评论
GMT+8, 2025-1-23 09:19 , Processed in 0.750391 second(s), Total 44, Slave 39 queries .
