您好Xilinx社区,
我喜欢在时钟ADC和FPGA Spartan 6的通用时钟之间以90°的方式提供相位信号。 之前,我的信号使用not功能进行180°定相。 我的时钟信号只编码一位。 请问你能帮帮我吗! 最好的祝福, 以上来自于谷歌翻译 以下为原文 Hi Xilinx community, I like to have phase signal exactely in 90° between clock ADC and general clock of the FPGA Spartan 6. Before, my signal was phased by 180° using the not function. My clock signal coded in only one bit. Could you help me please! Best regards, |
嗨,
根据我的笔记,您希望在进入FPGA时将ADC时钟相移90度。 如果我错了,请告诉我。 为此,您可以使用FPGA内部的MMCM或PLL来进行相移。 使用ISE安装打开coregen工具并打开Clock Wizardcore以根据需要生成输出时钟并进行所需的相移。 检查Xilinx.com上的Clocking Wizard文档,了解这个核心。 谢谢,AnirudhPS:请将此标记作为答案,以防它有助于解决您的问题。如果帖子引导您找到解决方案,请给予赞誉。 以上来自于谷歌翻译 以下为原文 Hi, From what i understand from your notes, you want to phase shift the ADC clock by 90 degrees when it enters the FPGA. Let me know if i am wrong. To do that you can use the MMCM or PLL inside the FPGA to doe the phase shift. Open the coregen tool with the ISE installation and open the Clock Wizardcore to generate the outputs clocks as necessary with the required phase shift. Check for the Clocking Wizard documentation on Xilinx.com to understand about this core. Thanks, Anirudh PS: Please MARK this as an answer in case it helped resolve your query.Give kudos in case the post guided you to a solution. |
2568 浏览 7 评论
2904 浏览 4 评论
2359 浏览 9 评论
3453 浏览 0 评论
2540 浏览 15 评论
2971浏览 1评论
700浏览 1评论
573浏览 1评论
864浏览 0评论
GMT+8, 2025-4-5 17:28 , Processed in 1.369232 second(s), Total 75, Slave 59 queries .
